Health & Beauty Logo
Posted on Dec 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The blanket doesn't heat. It's properly connected. The control box has two LEDs that keep on flashing regardless what I do with the wireless remote. I have two remotes, each one set for single side use--left and right. The batteries are fresh. The control box has two small slide switches under a small access panel. They are both set to 1. I've tried setting them to 0, one at a time. Nothing happens. The two lights on the control box keep on flashing and the blanket doesn't heat. HELP!
Duane Wong
Level 3:
  • Master 6,826 Answers
  • Posted on Dec 18, 2010
Duane Wong
Master
Level 3:
Answers
6826
Questions
6
Helped
2859853
Points
20233
I think the board is burnt out on the unit and is in need of service or replacement through Sunbeam.
One can contact Sunbeam at 800-892-7684 for bedding.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 04, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
478
Points
Remove connection plug from blanket and then reconnect to blanket and flashing should stop.
What does E 1 mean on the control. My blanket does not seem to get warm
E1 Is usually due to a bad connection or wiring error - broken wire etc.
"E1" appears for several reasons:• The wireless connection between the remote and control box can't be established.• The plug between the control box and the blanket is loose.• The plug from the control box to the AC outlet is disconnected. "For additional help "https://www.6ya.com/callphilipforhelp
Feb 08, 2019 • Home
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
1helpful
The 2 controls to our electric blanket are flashing "FF". What does that mean, plus there's no heat at all from it.
With the Sunbeam blankets that I have owned, FF meant that there was a bad connection somewhere. Have you tried the unplugging and replugging the Controller cord back into the blanket? Make sure it is plugged in GOOD AND TIGHT. If that part is connected as tightly as it can go, you may have a defective element.
2helpful
3answers
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 • Home
3helpful
2answers
7helpful
4answers
I tried to connect my controller to the ps3 and all it does is it just keeps blinking, help me
Putting batteries in controller
Turn on the PS3
Turn on controller
Press the sync button, the LEDs will flash rapidly
Insert the usb that comes with the controller, the LEDs flash slowly
Press the home button on the remote
READY.
6helpful
Won't work
Turn on the PS3
Turn on controller
READY.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
