Question about Frigidaire 30 in. Electric Gallery Pro Series Single Self-Clean Wall Oven
Cant unlock oven door - Frigidaire 30 in. Electric Gallery Pro Series Single Self-Clean Wall Oven
  • 2,382 Answers
Hi, unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door. If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
*Note: Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Posted on Dec 18, 2010
2 Suggested Answers
SOURCE:
reg501
  • 413 Answers
SOURCE: cant unlock self clean oven door
Door lock motor has probably failed.....Self clean on many ovens can be a self destruct mode. Door latch motors, sensor probes and even the electronic controls can be destroyed by this operation. Suggest oven cleaner method.
Posted on May 29, 2008
Had cleaned GE oven yesterday using SELF CLEAN and today my oven will not work as it keeps flashing UNLOCK DOOR when the door is already open. Cant use the oven
There is a sensor/switch that sends a signal that the oven door is locked and that it is unlocked, it must be defective.
Jan 11, 2017 | GE Ovens
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
Oven was clean self cant seem to unlock door and stop it
Have you turned the selector know off of self clean setting. Usually this will unlock the door. Good luck.
Sep 14, 2011 | Kenmore Ovens
I cant get my self cleaning oven to unlock... what do I do, I cant find my manual
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Oct 10, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I cant get my oven to unlock its door
you will needto let it go through the cleaning process to comeplete the cycle for the door to unlock,thats about the only way its going to unlock now
Dec 06, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
White westing house stove cant open oven door
try pushing self clean then cancel or stop/clear
Jun 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Cant unlock self clean oven door
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
My self cleaning oven will not unlock
i would try to set fro a clen clycle again, it should try to relock the door and then simply cancel cycle and should reset. or try turning off breaker, upon restoring power it should check the door latch mechinism and unlock
May 11, 2008 | Whirlpool RBS275PD Electric Single Oven
How to user self cleanning feature for oven
my oven is on f 9 cant turn off and get oven door to unlock
Feb 17, 2008 | Maytag CWG3100A Gas Single Oven
Frigidaire 30 in. Electric Gallery Pro Series Single Self-Clean Wall Oven Logo
251 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Ekse
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
