I recently had this happen too. My 2 year old dumped a bunch of juice down the front. It crawled up the front of the screen and looked like I would have to replace the screen. I just opened it up and cleaned the juice out the best I could, I then used Windex to make sure the screen was good and clean. I made sure all the Windex was dry before putting it back together and it looks like new! Was a little scary, but it worked great.
Need to dis assembly the frame of the tv and take the 3 screens out and cleaned may sure you put this back in the same way you took it o each side is different do not use any cleaner like windex
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
