I have a e howard watch and just replaced the battery, can not get the back of it into place and can not reset time. Where can I send for repair I really like and want to keep this watch.
You may send it back if you have a receipt ,lol,but here is an easier way for you:)
Of all things, you should always just try replacing the battery in your digital watch. These are really inexpensive and most watch stores will install your battery for you for free if you need help, but the process is very simple too. Most watches contain instructions on the back of the watch for replacing the battery. You opening the back panel carefully and review what is inside. You should see a battery that is small and round and metallic in color. Very carefully remove this battery and push the new battery into the exact same position, as the old one and it should fit into place. You should then replace the back panel and try out your watch. There are many good watches that were tossed away due to just a dead battery.
If your digital watch has gotten wet, try opening it up and removing the battery and airing it out. Use a really soft Q-tip to get at areas where there might be sensitive material that can damage easily. Try to dry up as much of the liquid with the Q-tip as possible and let the watch sit unused for a good while. Most digital watches will work if you get to the wet damage quickly enough and dry it up.
This is the model with the exposed button on the right side. The back does not come off, but the front does! If you use a loop you may be able to see a notch between 7 and 9 O'clock. Be very careful because the gasket keeping the watch water resistant is right there. You do not want to harm it. I put the watch in a holder and place a very thin jewelers screw drive on the side. With a jewels hammer I tap lightly until the front comes off. You must then carefully remove the movement from the case and not touch the hands. In order to close the watch after battery replacement, a watch press is a must. Without the press, you won't get the watch closed. The manufacturer suggests taking the watch to a qualified professional. You can send it to the manufacturer as well and they will change the battery for you. The Manufacturer is La Crosse Technology in La Crosse Wisconsin.
No, just set properly. This watch is very difficult to set. A watchmaker may be able to help you. The instructions are not very clear. You might try a watchmaker for assistance or try calling them although I have not had much luck along those lines.
does it have a slot on the back ? usually Nike watches are made to easily replace the battery usually with a nickle slot on the back or screws on the corners. The batteries they have are usually common 2806 or similar coin sized batteries. It will say on the back of the battery .
Most jewelry or watch repair shops can easily replace these batteries. if you bought the watch within a year , have receipt and something is broken. You can send it back to nike to be repair for free. It is done by parsec located here http://www.nikewatchrepair.com/.
ok place watch on window ledge inside house ..when you go to bed make sure its sat on a book with nothing else in its way except the glass window, the signal should be picked up by your watch between midnite and 3am that is sent from one of 5 world wide beacons.if this does not work have battery refitted and make sure the repairer AC's the watch this has to be done any repairer will know what you mean..
send your watch into skagen since you have a lifetime warranty you do not want to breech that. plus they reseal your watch and other watch repair places cant.
http://www.skagen.com/service/home.fx
You need a new battery, as there is not enough power to move both gears. You can send it back to Wenger and get battery replaced or just pop into your nearest watch repair shop and get it replaced. It will cost you $5.oo and will be done in 10 minutes time instead of months of waiting it back from Wenger. Rate me, plz.
This model watch uses two battery, an lithium battery is for digital and there is another silver oxide battery which were installed beneath the lithiem battery, all you need to do is remove the lithium battery then replace the silver oxide battery, the battery # is 377.
