Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
Posted on Dec 18, 2010
Zoom ring stuck between 45 and 55. Also focus ring when on manual.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Dec 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
Helped
7535
Points
22
Take it to the nearest Camera Shop.
Why does the focusing ring on the efs 55-250mm not retract all the way when you turn the camera off
I doesn't return to it's closed position when the camera is turned off. You have to do it manually . Turn the zoom ring to the 55 position then turn the front focus ring fully to the left.
Zoom focus
It has a magnify feature on the remote I think. You can reset the machine by holding down power computer and video buttons for a long time.
6helpful
Aperture ring won't turn
When the camera is set to autofocus, let the camera do the focusing. If you want to focus manually, turn off the autofocus so you can turn the focusing ring.
1helpful
Auto focus at full zoom not responding Nikon D80 with 18-200mm VR
Hi - I own this lens and it manually focuses at all focal lengths (hard to see at 18mm unless your subject is extremly close). You may need to get the lens checked. BTW - Mine was set as follows when I checked for you:
  • D80 was "on"
  • M/A
  • VR = Off
  • Normal (not Active)
Hope this helps!
Canon lins
This is normal. The zoom ring will stop at each end of the zoom range, but the focus ring will rotate freely, there is no "end" or "stop" to the focus ring.
2answers
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Losing focus
Usually this is a back focus problem; also called a flange back adjustment.  If the back focus adjustment is possible on this camera, zoom out wide - open iris all the way - and adjust focus and lock position.
Nikon AF-s VR zoom-Nikkor 70-300mm
First the auto focus motor is in the body and not the lens so that will not be the problem. Unless you dropped the lens the problem is probably in the focus gear interface inside the lens ( it is stuck in the manual drive --that is why no autofocus-- and there is something preventing normal gear operation). Seems like a small problem but will require a look at the rear of the lens where the gear box is situated.
Quantaray 28-90 for Nikon N65 zoom ring locked up
There is no secret locking switch. If a little gentle jiggling doesn't free the zoom ring, then I can only suggest you take it in to a reputable camera shop for a Clean-Lubricate-Adjust (CLA).
Can I manually control the zoom and focus?
Yes. Zoom can be controlled either by a variable speed rocker control, or a zoom ring on the lens. Focus is either automatic or manual via a focus ring.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
