How can i know my samsung lcd monitor model number? i m getting blue lines after starting my desktop pc. Blue lines on my monitor on left and right. Please help me
Re: How can i know my samsung lcd monitor model number? i...
Look on the back for the monitor there are a sticker with the info. change setting from computer display to lower resolution and display syse by starting to save mode F8
HI I got my model number - TFT LCD monitor 740 NW. -- My problem is not solved. I checked cable also.. and the display properties also. Please help me. On Samsung website I found Magic Tune, Magic Bright.. What are these softwares?HI I got my model number - TFT LCD monitor 740 NW. -- My problem is not solved. I checked cable also.. and the display properties also. Please help me. On Samsung website I found Magic Tune, Magic Bright.. What are these softwares?
You can't post conmments that contain an email address.
Unfortunately the line didn't show up in the video.
1) New LCD screen? Should have an Installation CD Disk that comes with it. Use it if so. Has the Drivers on it.
Driver: Small piece of software that allows the Operating System to communicate with a device.
Don't know which version of the Windows O/S you have. The device in this case is the LCD monitor.
2) What is the NATIVE screen resolution for the LCD monitor. Look up the specs on the monitor using it's Model Number on back.
For example I installed an HP 2009M 20-inch widescreen monitor, along with the 26-inch RCA ENV HDTV I use for a monitor.
I had to use the drivers from the disk, but could still not set the native resolution in Display Properties. There is an alternate resolution to the native one that can be used. The drivers from the disk made it so.
The 20 inch widescreen is 1600 x 900 (Pixels) The 26 inch HDTV is set at 1360 x 768 (Pixels)
Right-click on an empty area of your desktop screen. Left-click on Properties at the bottom of the list. In the Display Properties window click on the Settings tab.
What is the Screen resolution setting? What is it supposed to be? The Slider on the line is clicked on with the left mouse button, left mouse button held down; then the Slider is slid to the left to decrease screen resolution, or to the right to increase with the mouse.
Color quality should be set to High (32-bit)
1) Installing software (Drivers) from the Installation disk, (Or from the monitor manufacturers support website); And, 2) Setting the screen resolution;
doesn't help, replace the monitor cable with a known to be good one.
Suggest you go to AOC Support, Downloads>Manuals, and type the exact model of AOC monitor that you have. Download the User Manual.
For example:
http://us.aoc.com/support/downloads
Product Category: Left-click on the blue down arrow, to the right of this box. Left-click on LCD Monitors
Model Number: Left-click on the blue down arrow to the right of this box. Scroll down, and left-click on the model number of your AOC LCD monitor.
After you have done this, a drop down menu will appear. Where it states your monitor's model number, and the word - MANUAL, go to the right, and click on the white - Download.
The User Manual is in PDF file form. Give it a few seconds to download.
OSD Lock/Unlock Allows you to secure the current control settings so that they cannot be inadvertently changed. You can unlock the OSD controls at any time by using the same procedure. Push and hold the Menu ( ) button for 10 seconds or more to Lock or to Unlock.
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
well, my monitor is going back to samsung for a replacement unit. I plugged in my monitor in a bunch of other PCs and it's doing the same thing regarless of the PC or graphics card I use. Now I know it's the monitor. Getting it RMA'd with Samsung. Only had it for 18 days. Hope they send me a new one and not a refurb.
I was just looking at Samsung's site regarding this issue. It is most likely a line of dead pixels.
Direct from their site:
"The thin red, green, blue, white, black, or yellow line you see running through your LCD monitor is most likely a line of dead pixels. To fix this problem, you will have to get your monitor serviced or, if the monitor is new, replaced.
To set up a service appointment, contact Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your monitor's model number and serial number on hand when you call."
http://erms.samsungusa.com/customer/sea/jsp/faqs/faqs_view.jsp?PG_ID=1&AT_ID=15336&PROD_SUB_ID=28&PROD_ID=-1
