Trekstor i.Beat move  MP3 Player Logo
Posted on Dec 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SOFTWARE UPDATE - Trekstor i.Beat move MP3 Player
Level 3:
  • Master 17,130 Answers
  • Posted on Dec 18, 2010
Master
Level 3:
Answers
17130
Questions
0
Helped
3631707
Points
52372
Please find the link for your downloads in the following link :
i beat move
2helpful
2answers
How to update Kindle e-reader software?
Amazon.com Help: Kindle E-Reader Software Updates
www.amazon.com > help > customer > display
These free software updates include general improvements and performance enhancements. Note: Determine what Kindle E-Reader model you're using before ...
Amazon.com Help: Manually Update Your Kindle E-Reader ...
Manually Update Your Kindle E-Reader Software. Using a computer, download the file for your Kindle from Kindle E-Reader Software Updates. Turn on your Kindle. Connect your Kindle to your computer using the included charging cable. Drag and drop the downloaded update file from your computer onto the "Kindle" drive.
Kindle E-Reader Software Updates - Amazon.ca Help
www.amazon.ca > help > customer > display
Kindle E-Reader Software Updates. Software updates automatically download and install on your Kindle when connected wirelessly. These free software updates ...
2answers
How do u fix a iphone4 to make it update
There are several methods to update iPhone and following below steps can help you to reach this aim easier.
How to Update iPhone Software Wirelessly If a message says that an update is available, you could then click "Install Now" button to start to update your iPhone iOS software. Also, you could manually check whether there is an iPhone iOS update or not on your iPhone. The below steps would show you how to update iPhone software wirelessly:
  1. Before you update iPhone software via WiFi connection, you need to make sure your iPhone has enough storage and battery to support the iPhone update.
  2. Connect your iPhone to a WiFi network.
  3. Tap "Settings > General > Software Update" successively.
  4. Tap "Download and Install" option when your iPhone has detects an update available. If a message asks to temporarily remove apps because iOS needs more space for the update, tap Continue or Cancel. Later, iOS will reinstall apps that it removed.
  5. Then iPhone would start to download and install iOS update immediately. You only need to wait for the update complete.
How to Update iPhone Software with iTunes If you can't update iPhone iOS software wirelessly throug WiFi connection, you could give iTunes a try. As the all-inclusive iOS device manager center, iTunes provides multiple effective assistances for you, including: backing up iOS devices, restoring iOS devices, transferring iOS data files, and updating iOS devices. You could follow the below steps to learn how to update iPhone software with iTunes in detail:
  1. Install the latest version of iTunes on your computer.
  2. Connect your iPhone to your computer via the USB cable.
  3. Open iTunes and select your device.
  4. Click "Summary > Check for Update".
  5. Once iTunes detects the available update, click "Download and Update".
  6. If asked, enter your passcode. Then iTunes would start to update iPhone iOS software. When it's finished, disconnect your iPhone with computer.
For more methods, check: How to Update iPhone
How do I update my kindle?
Didn't update in time? Do a manual update At this point, you'll need to update your device manually. It'll require you to grab a USB cable and do the install with your Kindle connected a computer. Here's how:
  • Go to Amazon help page, find your device and click the link in the neighboring column to download the update. Use the above instruction to find out which software your device is currently running. In some cases, you might need to download and install more than one update.
  • Plug your Kindle into your computer. Once it appears as a drive, drag and drop the update file to your Kindle. (Not a subfolder, just the top-level Kindle drive.)
  • Eject your Kindle and disconnect the USB cord.
  • On your Kindle, go to Menu > Update your Kindle. Your Kindle will let you know when the update is complete.
abcFileHippo Download Free Latest Update Software and Printer Drivers
2answers
How to update iphone3 software
Before update your iPhone
  • Back up your device.
  • Check enough available space to install the update.
Update iPhone wirelessly :
  • Go to Settings > General > Software Update.
  • Download and Install the update.
If you are looking for updating with iTunes then follow Mac Support .
1helpful
3answers
Hello... nokia n73 my device software is V4.0726.2.04,can you help me to update it?tnx and more power
first of all you have to download the software updater from the nokia webite..and once your done,connect your cellphone to the computer with a USB cable..
update software:
With device software updates and application updates, you can get new features and enhanced functions for your device. Updating the software may also improve your device performance. You can update your device's software using the Software Updater in your device or using the Software Updater PC application. Learn how to update your device's software using both methods.
It is recommended that you back up your personal data before updating your device software.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting. installation of an update.
Downloading software updates may involve the transmission of large amounts of data (network service). Make sure that the device battery has enough power, or connect the charger before starting the update. After you update your device software or applications, the instructions in the user guide may no longer be up to date.
Update device software using your PC You can use the Nokia Software Updater PC application to update your device software. To update your device software, you need a compatible PC, a high-speed internet connection, and a compatible USB data cable to connect your device to the PC.
To get more information and to download the Nokia Software Updater application, go to www.nokia.com.ph/softwareupdate.
Update software over the air Your service provider may send device software updates over the air directly to your device (network service). This option may not be available, depending on your device.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting installation of an update.
Request a software update
  1. Select Menu > Ctrl. panel > SW update.
  2. The device scans for available updates.
  3. Select the desired update from the list, and follow the instructions on the screen.
  4. If the installation was cancelled after the download, to start the installation, select Install sw update.
The software update may take several minutes. If there are problems with the installation, contact your service provider.
2helpful
2answers
How can I update the software of my Nokia N958GB China Made RM - 355
Nokia's European site offers an update here:
http://europe.nokia.com/support/download-software/device-software-update/update-n95-8gb
Apr 04, 2011 • Cell Phones
Mtorola v3i ka software update kaise hoga
firstly you require the following on your system:-
  • 400MHz or higher processor speed
  • 256MB RAM or higher
  • Approximately 250MB of available hard disk space
  • Available USB port (USB 1.1 or higher)
  • Internet connectivity (Internet Explorer)
  • Windows XP (Service Pack 2) or Windows 2000 (Service Pack 4) or Windows Vista (either 32-bit or 64-bit) (Service Pack 1) or Windows 7 (either 32-bit or 64-bit)
NOTE:
During the software update, all third-party media, including but not limited to, music, pictures, ring tones, and screen savers, will be deleted. You will need to reload all third-party media after the software update. Third party applications and some custom settings CANNOT be automatically restored after the device has been updated. Please note that during the update, you will have the opportunity to save your personal data.
Please follow these steps below to download the Software Update
1. Connect your phone using the USB cable provided with the Motorola phone
2. download the update from the link provided below.
MOTOROLA UPDATE FOR MOTOROLA V3i
3. this will notify you if it contain a update for your Motorola model.
This will successfully update the software of your Motorola phone.
3helpful
I need a software update for my phone moto rokr e6
Please download this file and install it to update your moto
Please click here
step1.jpg You need the following USB cable type to perform the Software Update : Mini USB Data Cable. If you don't have a USB cable, you can purchase it here. Motorola Software Update provides the latest approved software for devices that are in warranty. Please note that your device's warranty status will be automatically verified prior to proceeding with an update. Please also note that your device may already contain the latest software available for your product. Motorola Software Update will notify you if an update is available once you download the update application and connect your device.
var strMonthSession='' var strYearSession='' if (strMonthSession=='1') { document.write("Jan"); } else { document.write("Jan"); } if (strMonthSession=='2') { document.write("Feb"); } else { document.write("Feb"); } if (strMonthSession=='3') { document.write("Mar"); } else { document.write("Mar"); } if (strMonthSession=='4') { document.write("Apr"); } else { document.write("Apr"); } if (strMonthSession=='5') { document.write("May"); } else { document.write("May"); } if (strMonthSession=='6') { document.write("Jun"); } else { document.write("Jun"); } if (strMonthSession=='7') { document.write("Jul"); } else { document.write("Jul"); } if (strMonthSession=='8') { document.write("Aug"); } else { document.write("Aug"); } if (strMonthSession=='9') { document.write("Sep"); } else { document.write("Sep"); } if (strMonthSession=='10') { document.write("Oct"); } else { document.write("Oct"); } if (strMonthSession=='11') { document.write("Nov"); } else { document.write("Nov"); } if (strMonthSession=='12') { document.write("Dec"); } else { document.write("Dec"); } for (i=2004;i"+i+""); } else { document.write(""+i+""); } } warranty-check.gif spacer.gif --> During the software update, all third-party media, including but not limited to, music, pictures, ringtones, and screensavers, will be deleted. You will need to reload all third-party media after the software update. Third party applications and some custom settings CANNOT be automatically restored after the device has been updated. Please note that during the update, you will have the opportunity to save your personal data.
Thanx and i hope this helps
4helpful
How can i update my moto e6 phone
Please click here
step1.jpg You need the following USB cable type to perform the Software Update : Mini USB Data Cable. If you don't have a USB cable, you can purchase it here. spacer.gif step2.jpg Motorola Software Update provides the latest approved software for devices that are in warranty. Please note that your device’s warranty status will be automatically verified prior to proceeding with an update. Please also note that your device may already contain the latest software available for your product. Motorola Software Update will notify you if an update is available once you download the update application and connect your device.
step3.jpg During the software update, all third-party media, including but not limited to, music, pictures, ringtones, and screensavers, will be deleted. You will need to reload all third-party media after the software update. Third party applications and some custom settings CANNOT be automatically restored after the device has been updated. Please note that during the update, you will have the opportunity to save your personal data.
Please donot forget to rate this solution
Top Trekstor Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Trekstor Audio Player and Recorder Expert? Answer questions, earn points and help others
