Ok let me ask a few questions. 1.You said U have A 1HP Sub. It pumps from about 300'. How did U get this info? 2.Now the water goes into A 120 Gal storage Tank from the top,then goes out from the bottom. Is Tank A Plastic or Galvanized/PSI Tank. OK NOW.BASED ON THE INFO THAT U PROVIDED.ON THE ISSUES THAT U R HAVING. IT SOUNDS LIKE YOUR TANK IS WATER LOGGED. WHAT THAT MEANS IS.YOUR TANK IS FILLED TO THE TOP WITH ONLY WATER. SO THE ONLY TIME U GET PRESSURE IS WHEN THE PUMP TURNS ON. NOW TO FIX THIS WATER LOGGED TANK PROBLEM.ALL U NEED IS AIR. SEE WHEN THERE IS AIR IN THE TANK & THE PUMP TURNS ON. WATER GOES INTO THE TANK.IT COMPRESS THE AIR WITCH CREATES PSI. Let me ask u another question. By any chance,before this booster pump was installed.Have U noticed your system turning on & off rapidly.Like all the time.How about your power bill.Has it been kind of high.
The booster should have been placed after you restrooms with a check valve to prevent back-pressure. then you can adjust both the sub-pump pressure, and the booster pressure accordingly
let me know
