Yes you secure that GREEN wire to EARTH, that bare wire and screw will do just fine.
A dimmer usually goes "IN" the PHASE line, BLACK, and in Series with any "Load" usually there is One Black IN from the Main Power, the Other, an OUT BLACK, still Phase, this side goes to the "Hot" side "Load". The "Other" side of the "Load" is called the "Cold" side, and that goes to neutral.and the circuit is complete.
It looks like the old one was IN on Black, and OUT on White. White went to hot side of load...the other wire is hooked up to the main Phase wire..supply..
Many thanks! This solution worked perfectly!
James Pugh
