SOURCE: my simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
SOURCE: I need a manual for Simplicity Pro Serger SW432
I went to Simplicity's website and downloaded the manual for free. Hope this helps.
SOURCE: threading instruction for model #1220 simplicity
http://www.sewingstyle.com/Simplicity-Sewing-Manuals.htmlnot
not sure if you have the manual, try this site for a manual,
SOURCE: Babylock Serger Question
You might take a look on eBay item # 150373367524
Thank you for the question
SOURCE: Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
