PCAmerica does usually recommend turning off all firewalls, windows and others. However, they also have a procedure for running the sql server on a static port that will allow the firewall to be turned on using exceptions for this static port. I have never tried this option, but I can send it to you or try and help you.
B Mattern
[email protected]
Please return and give me a favorable rating if this helps or is of value to you.
Testimonial: "Thank you for this advise, Yes please send me the fix you are recommending. Thanks Alan"
I'm getting the same error all the sudden, what is the procedure so the data table can connect again.
