Start by closing the hopper and grinding all the beans through the unit. Remove the hopper and look for any lock screws on the top of the adjustment collar (or ring). Remove the screws if present and turn the adjustment collar clock-wise (coarser) until it comes off. Pull out the upper burr holder. You then need to take out the three screws that hold on each burr (blades) and remove them. Then you want to use a shop vac to clean out all of the grounds. Make sure there is no coffee on the burr holders that could cause the new burrs to not be level. Assemble the new burrs on to the holders. Take a dry towel and clean the threads of the collar and the threads inside the mill. You don't want any coffee grounds on the threads, that could cause the adjustment collar to lock up and may damage the threads which can be extremely expensive. Use a small amount of lithium grease on the threads and reassemble. Screw the adjustment collar all the way down to where the burrs are touching. Then back it up 1.5 numbers (12-14 little bumps on the outer edge of the collar). This is a good "starting point". Pull some shots and adjust as needed.
good luck
[email protected]
