HP DeskJet 1280 InkJet Printer Logo
Posted on Dec 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Instal hp dekjet 1280 with hp wireless printing upgrade kit in windos 7
Michel Smith
Level 3:
  • Master 1,218 Answers
  • Posted on Dec 30, 2010
Michel Smith
Master
Level 3:
Answers
1218
Questions
Helped
795102
Points
2925
Wireless printers may face an installation problem with Windows 7 operating system. For example, Toshiba laptop is compatible with this operating system yet it may require a driver download for executing a print command on wireless printer. To combat this challenge, users are advised to delete and re-install the printer. If the problem persists assign the wireless printer to a fixed address through a router instead of the Dynamic Host Configuration Protocol (DHCP). Accessing the wireless printer from a laptop with Windows 7 operating system can be a challenge. Often, it may display the printer to be offline. To resolve the issue, users must cancel printing jobs immediately and delete offline printers from the Printers option in the Control Panel. Visit the Printer properties and access the Ports tab, delete the printer that displays the offline status and appears as Client Side Rendering Provider. Delete the Port button and click apply. Restart the PC. Now re-install the wireless printer by visiting the Control panel, opening Printers and clicking option add a printer. Now select add a local printer, followed by selecting the option "Use an existing port", LPT1: (Printer Port). Install the printer driver offered by Windows 7. In the next window leave the Set as a default printer box unchecked and re-name the printer. Click Next. Upon successful installation, the operating system will display the message "You've successfully added printer name"
1helpful
How to sync a wireless printer with an iPhone?
That printer does not support AirPrint, which is what you need to "sync" it to your device. If you still want to print from your device, there is an App from printopia that you can install on a local computer that will act as a gateway, but the recommended way from hp is to purchase a wireless connection kit
Here is the callout from the manual
Get everything you need to print wirelessly with the
HP Wireless Printing Upgrade Kit (Q6236A).
I want to install hpo deskjet 1280 for windos 7
Unfortunately if HP does not support the printer for your OS and neither does Microsoft then it may be worth looking at a newer printer as they are now so cheap.
3helpful
Hp deskjet 1280 windos 7
HP deskjet 1280 printer free software for windows 7 (64-bit)
Hp inkjet 1280 is coneccted to computer with windows xp instaled. this is shared printer and we use it over other computers in the network. some of them with windows xp prints great on it, but there is...
This seems to be quite a common problem, you will need to upgrade the Hp drivers on your window 7 computer's.. Try driversguide.com or drivershq.com they should be able to help.
Hope this helps.
112helpful
6answers
Hp deskjet 1280 driver printer for windows 7
download hp deskjet 1280 for win 7 32 bit http://www.wupload.com/file/3797628/HPDJ1280_for_win_7.exe
When I try and connect the HP wireless upgrade printing kit it doesn't recognise the adapter and so won't procede. Any ideas?
you do not need an upgrade kit.....this printer is a wireless printer.....so can use it wirelessly without any upgrade kits.....just need to run the wireless setup wi\zard on the printer from the front panel menus and then nyou have to install the s/w using the disc that came along with the printer and you need to select the connctivity as wireless and then follow the on screen instructions...
1helpful
HP Wireless Printing Upgrade Kit - HP G55 Officejet Printer?
Yes ; The Officejet 6000 series os one of thse listed on the HP website under the "Wirless upgrade kit" that is compatable.
Can't connect wirless to the printer I
Hi Judi,
I'm not sure but if I remember correctly the Hp F380 is a 3 in 1. I have used similar models. But did you install something like this
Miscellaneous Accessories s.gif s.gif q6259a_70x100.jpg HP Wireless Printing Upgrade Kit Q6259A s.gif Product name HP Wireless Printing Upgrade Kit s.gif Compatibility: View complete compatibility list
1helpful
Sharing HP PSC 1410V All-In-One
Yes, you can and it is pretty easy.
You should get the HP Wireless Printing Upgrade Kit
(Q6236A#A2L)
Price: $69.99
Here is there product description from HP.
Get everything you need to print wirelessly in this simple upgrade kit! It includes a printer receiver and PC receiver for a wired desktop or notebook PC, and it's easy to both install and use.
Works with most HP printers and All-in-Ones, plus all PCs, wired or wireless.
* Print from virtually anywhere in your home or office via the wireless 802.11g connectivity
* Eliminate ugly cable clutter but still get the same print speeds as via USB
* Retain full all-in-one wireless functionality: print, fax from your PC, scan, and access photo memory cards access and PC status
* Set up fast: just plug the receivers into your printer and PC; there's no configuration
* Protect your signal from interception with the secure wireless connection
* Use with a network, or just one PC
* Compatibility: most HP printers, all PCs (wired or wireless)
** I checked and your HP is on the compatibility list - it is ok***
What's in the box?
1 printer receiver
1 PC receiver
William
k24674
Grand Canyon Tech
Grand Canyon Tech
