Dishwashers Logo
A
Anonymous Posted on Dec 17, 2010
Will not drain - Dishwashers
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Dec 18, 2010
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232345
Points
12714
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
2helpful
Does a Samsung washing machine model WA12VP have a drain pump? It has a drain motor to activate the draining valve for draining right? Thank you.
Yes, the Samsung washing machine model WA12VP has a drain pump. The drain pump is responsible for pumping water out of the washing machine during the draining stage of the wash cycle.
It is possible that the issue you are experiencing is related to the drain valve rather than the drain pump. The drain valve is what opens to allow the water to flow out of the machine, and if it is not opening properly, the water will not drain.
To troubleshoot the issue, you can try manually opening the drain valve to see if water flows out of the machine. If it does not, then the issue is likely with the drain valve and it may need to be replaced.
If the drain valve is working properly, then you may need to check the wiring and control board for issues that may be preventing the drain pump from activating during the draining stage.
3helpful
Water will not drain. humming noise
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Humming noise is due to loose connections on drain pump or due to faulty drain pump.
Daniel
2answers
My dishwasher is not draining all the way where is the drain? Maybe it is plugged?
Hi
Drain is plugged, leaking water
Hi
1helpful
Will not drain completely problem started after a power outage.
Hi
1helpful
Dishwasher is not draining
Hi
My dishwasher cleans ,but does not drain the watr fully. Please help. Thanks
Hi
Not draining and making noise
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump. The noise you are hearing is from the drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Daniel
Aug 20, 2010 • Dishwashers
Won't drain
Hi
Daniel
Dishwasher does not drain in normal cycle. on
Thoroughly clean drain screen and drain. Add small amount of drain cleaner to drain, flush after five minutes. Do not add hot water with drain cleaner.
Jul 07, 2009 • Dishwashers
Top Dishwashers Experts
Mike Cairns
Mike Cairns
