Computers & Internet Logo
Posted on Dec 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have no driver foe instal my Wireless adapter
Anonymous
Level 2:
Sergeant:
Novelist:
  • Expert 198 Answers
  • Posted on Dec 17, 2010
Anonymous
Expert
Level 2:
Sergeant:
Novelist:
Answers
198
Questions
Helped
75427
Points
505
You need to check for the model/brand of your wireless adapter then go the manufacturer's web site to download its drivers.
I need gateway address and subnet mask foe canon irc2620n
Are you trying to connect to a wireless printer? Open your wireless adapter properties. In windows 7 , Open the Network and Sharing Center, Change adapter settings, Right click on your wireless adapter, open status, Details. Or open Devices and Printers, Add a Printer.
Can i use a Netgear WPN111 USB 2.0 Wireless Adapter with a xbox ?
No definitely not....
If you want your Xbox to be wireless, then you need to buy Xbox wireless adapter...
Bcoz the Xbox wireless adapter comes with a pre-built in drivers....
but other brand wireless adapter donot comes with a built in drivers, you need to install the drivers using a driver cd....But Xbox do not allow driver cd's to be installed on it... so you will not be able to use ordinary wireless adapter instead of Xbox wifi adapter...
2helpful
2answers
How to install wireless adapter?
Hello faiz
you can download driver for your adapter from here
Click here to Download
actually this device is plug and play hardware but if you still having problem to install this adapter download driver for your adapter then install run the setup.exe file then plug your adapter when prompt
Regards
Manish
1helpful
How do I install my Belkin F5D7051 wireless adapter without the installation CD?
To install the adapter you will definately need a disc. because the adapter will not work without the Drivers. Drivers are very important for the adapter. One more thing that if you have WIN XP or VISTA then you don't need the set up utility but still you need the drivers for the adapter.
If you do not have the disc. You can download the drivers from the manufacturer's web site and install the drivers for your adapter.
Click her for more info about networking
2wire wirelessa card
Believe u r talking about updating ur drivers for the wireless card...
right click on my computer--->click manage--->click device manager on left hand side on the window that opens---->click the + sign next to network adapters----> right click on wireless adapter----> click update driver
any driver installation is free or u can log onto the official website of 2wire... look for drivers matching ur wireless card... download & install
would suggest, while installing driver after downloading should plug out the usb wireless adapter.
Driver is loaded but installer say cant find driver
just uninstall the driver and remove card. reboot reinstall driver then reboot and insert card should work now ./RICHARDM69
1helpful
I installed a linksys wmp110 wireless adapter into my gateway and it causes the computer to freeze up. i removed the card and the computer works fine. what can i do?
Reinstall Drivers
To re-install the wireless adapter’s drivers, you need to perform two steps:
  1. Uninstalling the Previous Drivers
  2. Reinstalling the Drivers
Step 1:
Click Start, All Programs or Programs, and look for the model number of the Linksys Wireless Adapter.
Step 2:
Look for Wireless Network Monitor and select Uninstall.
Step 3:
Wait for the Install Shield Wizard to complete before re-installing the drivers.
NOTE: Before re-installing the driver, unplug your LinksysWireless Adapter. If you’re using a wireless PCI adapter, shutdown thecomputer then remove the adapter.
The screenshots may vary depending on the model number of your wireless adapter. In this example, we’re using WUSB54GS v1.0
Step 1:
Insert the Linksys Setup CD into your CD-ROM drive.
Step 2:
Click Here to Start
to begin the installation process.
Step 3:
Accept the License Agreement by clicking Next.
Step 4:
Insert the wireless adapter into your computer and click Next.
NOTE: Ifyou’re using a wireless PCI card shutdown your desktop PC and open yourPC’s case. Locate an available PCI slot on the motherboard then poweron your PC.
Step 5:
When Linksys Wireless Network Monitor appears, select the name of your wireless network or SSID and click Connect. If you want to configure the adapter manually, click Manual Setup.
NOTE: To check if the drivers were properly installed, checkif the Linksys Wireless Network Monitor reports the Adapter is Active.For instructions, click here.
NOTE: If you were not able to install the Linksys adapter drivers, you need to update the drivers.
Update the Drivers
To update the wireless adapter’s drivers, you need to perform three steps:
  1. Downloading the Drivers.
  2. Uninstalling the Previous Drivers.
  3. Installing the Updated Drivers.
Step 1:
Before downloading the drivers, make sure your computer has an activeInternet connection. If your computer is plugged directly into therouter and cannot get online, disconnect your router and plug yourcomputer directly into your cable or DSL modem.
Step 2:
Once online, click here to go to the Linksys Downloads page..
Belkin F5D7050
http://www.belkin.com/au/support/
and then look for the driver you want from there
Installing pc card: 32 bit cardbus WG511
If your laptop is running on XP, sometimes WINDOWS installs the drivers for the wireless card automatically. If WINDOWS do not install the drivers, you need to load or install the drivers of your wireless adapter. You can use the disc that came with the wireless adapter or downloiad the drivers from the website of your wireless adapter
Grand Canyon Tech
Grand Canyon Tech
