I have Acer TravelMate 5510. Every time I switch on , I am asked to reboot or download the above Software
F Sway
Everytime I open certain docs. I get told that "eDataSecurity was not properly installed! Please re-install the software" I then click Ok and the it says Windows explorer has stopped working.
It's becoming an anoyence considering I can't use my windows2007 anymore :(
Is there anything I can do to re-install eDataSecurity,so I can live out happy days with my computer and not decide to throw it out my window??
I keep getting Web page has expired and switch off computer and re install Acer eData Management.Can you please help
Uninstall Acer eData security management completely, using add/remove programs from the control panel. Follow the link below to download Acer eData Security Managemant (for windows XP) again and reinstall. If you are using a different OS you will need to go up one level in the directory and select the correct operating system.
ftp://ftp.work.acer-euro.com/desktop/empowering_technology/Software%20XP/
Some attacments on email ask for file descryption password. Where can I find out my password or get rid of it so it doesnt ask for one?
Delete edata security completely.
Use the following to unlock your files:
http://www.egistec.com/oem-acer001/
Then download a free more reliable encryption / security tool if needed.
Administrator has prohibited access to USB/1394 mass storage devices and cd/dvd drives?
SOURCE: Acer eData Security Management
try logging in safe mode and reboot the pc after loading safe mode I have had programs crash installing and I loaded safe mode and restarted pc and in safe mode it fix the problem.. so when I restarted pc it worked ok.. the program mighted of corrupted and you might have to uninstall it and reinstall it I dont remember if acer has a app disk like dell,emachines(new),gateway or ifs a full restore disk.. Im thinking that its a app disk.. you might also want to check for viruses. with a program like house call free scanner from trend.. and spyware scanner free adaware. both are good.
if you still cannot login to windows you can run msconfig in run box and disable it in startup but becareful with what you disable
delete/uninstall edata security completely.
Then download a more stable security like AVG, McAfee or Norton, check this site some are having the same problem and this seems to be the best solution.
I have searched the Acer website and the user guide for your model and can find no reference to the edata software referenced. I think that a system restore is what you need. Per the manual press alt-f10 to enter the utilities and create a system restore cd and an application restore cd reboot with the system cd and restore the computer to a factory fresh condition. Remember that no user data will be saved so if you have documents or pictures etc. make a copy first. Good Luck
Mein Problem besteht darin, dass neuerdings beim start die ansage kommt installieren sie acerdatasecurity management neu. wie kann das passieren und wo kann ich dies onlie runterladen ?
I have a Home PC and I have the same thing popping up.
same problem: asks everytime to reboost
I have also had the same problem. I have put the back up on disk and have no luck with that either. Please help me !!!!
My problem is that,every time I turn on my PC,this message pops up "acer edata security management is not installed properly,pls reinstall it.I use the files in the C:Programme Files to uninstall and reinstall it,then everything works well,I can encrypt and decrypt many things.But the problem occurs the next time I switch on my PC.
same problem with acer aspire 9300
please solve this problem, its a pain
problem is,box shows acer e-data security management is failing please close all programs and reboot if problem persist please re install data security management again!
how do I re install??
this software is malfunctioning.please reboot the computer. and try again,if the problem persist, please close all running programs and reinstal Acer a data security management
same problem with acer 5630
Every time i repoot my laptop it gives me eror message that Acer eDatasecurity management is no istalled and it ask me to reinstall it
"problem with data securiy management" every time I re-boot from sleep. Temporarily solved by logging off completely but always recurs.
Have an Acer Aspire 5610Z. I keep getting the System Information, telling me the system is malfunctioning and telling me to reinstall the eData Security Management. It's a pain in the backside.
Any suggestions????
I have an aspire 5315-2153 that will keep posting the same notations while in my email Outlook,,,I have unchecked the drop down menu about Acer security managment, but it keeps reinstalling it,
I have not been able to figure how to remove that from happening.
A pop from edata security management saying software is malfuncting and i need to reboot the computer again or if problem presists i need to reinstall edata security management. My laptop is an acer aspire 5720.
Everytime I open my computer its popped out the message saying edata security is not installed properly.pls install the software
i also get the same message that my acer edata security program is not installed properly. But I cant reinstall it, and all my documents wich is password-protectet by this, will not open. So since my system is down, all my documents are locked.
What can i do?
i've got the same problem -.-'
yeh i have the same problem and if i ignore the the specified option it will pop up 20 times on my desktop until i close all the boxes.
I'm getting tired of seeing this notice pop up every time I turn on my Acer laptop. Its just an extra hindrance I don't need!
Regards,
[email protected]
fed up of the same thing popping up,all the time
how do i stop pop ups
I am always asked to reboot my computer or install acer edata security management if the problem persists.
i keep getting the pop up saying reboot reinstall acer edata security management
Like 100000 of people I have the problem of trying to fix my PC. I get the same message ; to re=install Ace e data security management prog. Plse help
This has been an ongoing issue for awhile now with no hope in sight. If you try one the products like TuneUpAdvisor(link on right of this page), you'll find out the download is free but the crucial repair options are not. You'd think by now there would have be an easy and free of cost solution but I've yet to see any useful feedback about this security situation with Acer.
im so sick of this dam acre edata,,,,wth
do i do ??????????????????????
how can I resolve this problem? Always compare: this software don't play corretly download acer secutity close acer data security and reinstall....
thanks so much
e data security. F____
When I boot up Vista it says please re-install edta security and the key icon on the widget doesn't load up like the rest.
ewerytime i open my notebok, i always have the same a problem, a box about the data security. system file error.
i unistalled ma edata security.. now what should i do to recover my things in personal secure disk... pm at [email protected]
how to i reinstall acer e management security? i have a desk top
where do i go to reinstall acer edata security management software
It started just after I updated my McAfee anti-virus software, so obviously that's the culprit. Pretty much every weird that has happened with my computers has been security software messing with the operating system. Of course, that doesn't mean I know how to fix it ...
i have used e security & encrypted my VPC but now it is not decrypting it starts & stops at 5% ............ Acer aspire 5920 notebook pc
i deleted edata security and dont know where the files have gone. [email protected]
