Microsoft Xbox 360 Console Logo
Posted on Dec 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My xbox makes a rattleing noise when the disk drive shuts and only reads some disks
Anonymous
Level 2:
Scholar:
  • Expert 95 Answers
  • Posted on Dec 17, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
95
Questions
0
Helped
24841
Points
274
JUST TRY :)
this is most common problem for 360 you can solve it by your self
first remove the xbox covering and take the disk tray and follow the video below
click here bro :)
Hi just changed the disk drive it will play dvds but when you play a xbox games the drive is very noisy and wont read or attempt to play it doesnt reconised any game. thanks
First I would make sure you replaced the disk drive with the previous one you had as there are several different types. If not you would have to flash the new drive to get it to read the game format. Your new drive shouldn't be making any loud noise by the way, you may have got a defective one
1helpful
My xbox 360 won't read any my games and makes noises when put game in what should i do
maybe there is something wrong with ur disk drive if so its a simple fix all u have to do is buy a new disk drive off ebay for $15 and take the xbox apart and then repalce ive had the same problem
2answers
Xbox 360 console can't read disk
If your console has stopped reading discs this can be because the receptors on the back of the drive have overheated and to fix it you will need to send it in or use a good repair guide to do the job.
My xbox 360 is not reading any disks and making a grinding noise then stops reading the disk
Yes this is normally because the DVd drive is taking too much heat, to fix it you need to stop the heat build up you can do this by sending it in or using a good Xbox 360 Repair guide
Disk Drive Problems
Your old xbox is not up to date, so it is reading it wrong. Just because the older they are if not updated on live it will read games and DVDs wrong.
2answers
My xbox 360s isn't working
In very rare instances I believe that the dvd drive of your xbox 360 might have been disconnected.In this case,it dispays an "open tray" message.For this you will have to open your 360 but please take it to the dealer if you are still protected by warranty.Good luck.Thanks for reading.
Xbox 360: disk drive
try reseting the system in the system settings this, is sometimes caused by an update not downloading and or installing correctly. once you reset to default, try updating  the system on xbox live. if this continues you might have a drive issue. good luck....
One day i was playing halo 3 and my disk drive starting making wierd, grinding noises and stopped then after the noise stopped my disk would stop spinning and now eveytime i try to read my disk my motor...
This hard disk is a easy fix, You can buy a new one for the fraction of the cost, All you have to do is slip this off the unit and apply an new or even a used hard drive. Here is some links for some hard drives http://catalog.ebay.com/Microsoft-Hard-Drive-120-GB-9Z600001-for-Xbox-360_W0QQ_fifptsZ1QQ_pcatidZ413QQ_pidZ70884347QQ_trksidZp3286Q2ec0Q2em271
you can get some for under 30 bucks. if this information helps please rate accordenly Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1helpful
3answers
Xbox 360 will not read disc and is making a weird noise
Is it doing this while the disc is in the drive? Also does it sound like a loud rattling sound?
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
