Sony Ericsson W850i Cellular Phone Logo
Posted on Dec 17, 2010
RUNNING v 1.01/UNI CARD SERIAL 00151975 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 2019 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35536301178203 CERT:N/A FLASH CID:49 COLOR:BROWN no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 6 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35536301178203 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 writing "D:\SE TOOL\w850\CID49\R1ED001_1250204_CHINA_CY.ssw\R1ED001_1250204_CHINA_CY.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 can't get packet start. HDR block not accepted,error: BA Elapsed: 78 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35536301178203 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 No situable fsloader found, exiting Elapsed: 12 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35536301178203 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 writing "D:\SE TOOL\w850\CID49\R1ED001_1250204_CHINA_CY.ssw\R1ED001_1250204_CHINA_CY.ssw.cry" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 9100 HDR block not accepted,error: 19 Elapsed: 109 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35536301178203 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 2019 Will read 00020000 bytes,starting from 44000000 Reading:131072 bytes Done phone detached Elapsed: 16 secs.
1 Related Answer
Anonymous
  • 668 Answers
  • Posted on Jan 30, 2011
SOURCE: my sony k530i connect to pc for gdfs backup it
Follow the steps mentioned below to take a backup:
1. Download latest version of xs++ software on your pc and install it.
2.Switch off the phone and remove the battery and reinsert it once again.
3. Click on connect and then Connect the USB cable to your PC while holding down the "C" button.
4. In configuration tab choose GDFS tab.
5. Click Backup GDFS.
If you still have a problem then GDFS is damaged so your phone will not work properly.
Hope this helps.
Please feel free to contact if you have any queries.
Shane
Zaiko e5 error how I can fix my ac
E5 indicates excessive temp. of the outside coil if on cooling, OR excessive temp of the inside coil in
heat mode. On cooling, the E5 will appear if the outside coil temp exceeds 68C. This is an indication
of condenser airflow reduced or non-existent. Using the procedure described above it is possible to
watch the condenser coil temp using the Temp down button and Medium fan speed combination to
display this temp. NB: if fans etc seem to be OK then measure thermistor resistance and refer to table
12. In case the problem is thermistor calibration.
Action: If unit is in cooling mode, examine both condenser fans are running. If
one is running then suspect a faulty motor. If both fans not running then
on units up to serial No. IBSA 01175, investigate the fan speed control
card located in enclosure on the LHS See fig 6.
If this checks OK then investigate main control card.
Fig 1, 2 or 3. Units with serial No's IBSA01176 and
onward are multi speed tapped wound motors not requiring a speed
control card. If both motors inoperative then suspect main control card
tip
Hi there.... I have tried the above, but nothing happens after I have clicked on...
Hi! I have noticed a lot of people have this problem that they actually forget there Sony Ericsson mobiles' Phone Lock Code. If you want to recover your phone lock code please go through the following procedure. This procedure will tell you your mobile's lock code without flashing and resetting of any kind!..
I have also have a Nokia version of this tutorial here: Nokia
Follow these steps;
  • Open this link, select your phone and download the software. (PLEASE CLICK HERE)
  • Follow the onscreen instructions to install the software.
  • Once installed, turn off the mobile and remove thebattery. Now reinsert the battery and insert the cable (DCU-60 thatcomes with the box) while holding the 'c' or '@' button on your mobile.
  • Your computer will detect a new device and install it.
  • Once installed please unplug your mobile, remove the battery. Now reinsert it.
  • Download xs++ from here
  • Extract this file and run XS++.exe
  • In XS++, click Connect.
  • Hold 'C' or '@' key on your phone and then insert the USB cable.
  • u can get some information about your phone when it's connected
  • click or tick GDFS at the bottom.
  • Then click Phone Lock, it will show you the code on right hand side. Note that code.
  • click Settings at the bottom, then Disconnect.
  • unplug the USB cable, remove then reinsert the battery.
  • You are done, enter 0000 or the Noted one (In the 3rd last step)
    If I was Helpful, Kindly Do Rate!
    Regards,
    Waqar.
    How to unlock china tablet 3100 fcc id A3L3100 rated: 5V-1A i forgot unlock id and password and i entered password too many times
    info >>> Getting Mobile Connection Info... VCC Pin:7, GND Pin:2, Signal Pin:3, 5, 6, 8, 9, 10, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:6 D-:8 >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM428 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:00002CBC Flash Size:20000000->512M Flash Name:NAND_SamSungMT29C4G48MAZAPAKD CPU Name:6820/8810 All Done...
    Sep 25, 2013 • Cell Phones
    Error 720 - the connection attempt failed because your computer and the remote computer could not agree on PPP control protocol. Gateway Desktop
    To resolve this behavior, follow these steps:
    1. Find out which protocols the RAS server is running, and make sure that the RAS service is installed and configured properly (or ask the Network Administrator to do this).
    2. After you find out which protocols the RAS server is running, make sure that your Windows XP-based computer is running one of the same protocols that the RAS server is running:
      1. Click Start, click Control Panel, and then double-click Network Connections.
      2. Under Virtual Private Network, right-click the VPN connection, and then click Properties.
      3. In the VPN Connection Properties dialog box, click the Networking tab, and make sure that you have a protocol that the RAS server is running.
    3. If you do not have a protocol that the RAS server is running, add the needed protocol:
      1. Click Install, click Protocol, and then click Add.
      2. Click the protocol that you need to install, and then click OK.
      3. Click Close in the VPN Connection Properties dialog box.
    2answers
    How can I fix error code 720.I first got this while trying to connect to a wireless network. I get it repeatedly when laptop is near any networks. Also pops when I click on some links.
    2helpful
    I want lock code for sony ericson k660i
    First download this software: Ultimate Unlocker v1.01 by Cruiser Team(search google its free!)
    Follow the example given below:
    Successfully unlock K660i (A2) 17:25:25 Ultimate Unlocker v1.01 by Cruiser Team 17:25:26 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 17:25:26 Initializing... ! 17:25:26 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 17:25:26 2. Choose the phone model ! 17:25:26 3. Select the desired options ! 17:25:26 4. Please connect the phone either via USB while holding 2-5… ! 17:25:26 - or via a serial cable and double-click on it in the device list 17:25:34 Connecting via Generic EMP USB Flash Device (USB1)… 17:25:34 Device driver version: 1.1.0.12 17:25:34 Device driver date: 9-25-2006 17:25:35 Connecting to the baseband CPU... 17:25:35 Entering baseband CPU service mode... 17:25:35 Detected chipset: DB3150 17:25:35 Boot mode: ROM 17:25:36 Sending loader... 17:25:37 IMEI: xxxxxxxxxxxxxxx 17:25:37 OTP CID: 52 17:25:37 Product type: Retail 17:25:37 Effective color: Red 17:25:39 Sending loader... 17:25:40 Communicating with server… 17:25:44 Remainig credit (supreme): 1.00 17:25:49 Remainig credit (supreme): 1.00 17:25:49 Converting phone to blue… 17:25:49 Please reconnect the phone (disconnect, connect while holding 2-5) 17:26:01 Sending loader... 17:26:02 IMEI: xxxxxxxxxxxxxxx 17:26:02 OTP CID: 52 17:26:02 Product type: Retail 17:26:02 Effective color: Blue 17:26:04 Sending loader... 17:26:08 Code NCK for relock: 9753585490502778 17:26:08 Code NSCK for relock: 3889412532359257 17:26:08 Code SPCK for relock: 3171907565654182 17:26:08 Code CCK for relock: 6478061648618760 17:26:08 Code PCK for relock: 3949070691496765 17:26:08 Code ESLCK for relock: 9101944641118096 17:26:08 Code NCK for unlock: 9012406338647640 17:26:08 Code NSCK for unlock: 2040670855123632 17:26:08 Code SPCK for unlock: 0923191541634191 17:26:08 Code CCK for unlock: 4556970785063717 17:26:08 Code PCK for unlock: 1754665636774190 17:26:08 Code ESLCK for unlock: 2257853277910517 17:26:08 To enter a code, type < * * < on the phone with SIM-card inserted 17:26:09 Turning off the phone... 17:26:11 Done. ! 17:26:11 Please disconnect battery and cable from the phone!
    Alternatively you can do this:
    hard reset *2767*3855# (this erases all ur data, you can preserve ur data by takin a backup.)
    2helpful
    Unlock code k660i on 3 network
    17:26:11 Done.
    Error message when using my new Microsoft Windows Mail program-
    You are supposed to put the fully qualified domain name of the mail server in the SMTP server field, and the POP3 server field, like mail.acmellc.com and pop3.mycompanyname.com. Contact your mail service provider if you are not sure what the server names are.
    1helpful
    Installing hp laserjet 4100dtn over the network using tcp/ip addr
    Hi admin30:
    Here is some info for you.
    EIO menu (networked printers)
    The EIO (enhanced input/output) menu appears only when an EIO device is installed in an EIO slot
    on the printer (such as an HP JetDirect print server). The items in the menu depend on the particular
    accessory product installed. If the printer contains an HP JetDirect print server EIO card, you can
    configure basic networking parameters using the EIO menu. These and other parameters can also
    be configured through HP Web JetAdmin.
    Table 27. EIO menu
    Item Values Explanation
    CFG NETWORK=NO NO
    YES
    Select whether or not you want to use
    the HP JetDirect menu.
    NO: Bypass the HP JetDirect menu.
    YES: Use the HP JetDirect menu. You
    must change this to YES each time you
    want to use the menu.
    Note
    You must select CFG NETWORK=YES to
    display the following items.
    IPX/SPX=ON ON
    OFF
    Select whether the IPX/SPX protocol
    stack (in Novell NetWare networks, for
    example) is enabled (ON) or disabled
    (OFF).
    DLC/LLC=ON ON
    OFF
    Select whether the DLC/LLC protocol
    stack is enabled (ON) or disabled (OFF).
    TCP/IP=ON ON
    OFF
    Select whether the TCP/IP protocol
    ATALK=ON ON
    OFF
    FG IPX/SPX=NO NO
    YES
    Select whether you want to use the IPX/
    SPX menu and set IPX/SPX protocol
    parameters.
    NO: Bypass the IPX/SPX menu items.
    YES: Use the IPX/SPX menu items.
    In the IPX/SPX menu, you can specify
    the frame-type parameter used on your
    network.
    The default is AUTO, to automatically set
    and limit the frame type to the first one
    detected.
    For Ethernet cards, frame type
    selections are EN_8023, EN_II,
    EN_8022, EN_SNAP.
    For Token Ring cards, frame type
    selections include TR_8022, TR_SNAP.
    In the IPX/SPX menu for Token Ring
    cards, you can also specify NetWare
    Source Routing parameters, which are
    SRC RT=AUTO (default), OFF, SINGLE R, or
    ALL RT.
    CFG TCP/IP=NO NO
    YES
    TCP/IP menu and set TCP/IP protocol
    parameters.
    NO: Bypass the TCP/IP menu items.
    YES: Use the TCP/IP menu items.
    In the TCP/IP menu, you can specify
    BOOTP=YES or DHCP=YES for TCP/IP
    parameters to be automatically loaded
    from a bootP or DHCP server when the
    printer is turned on.
    If you specify BOOTP=NO and DHCP=NO, you
    can manually set the following TCP/IP
    parameters from the control panel: each
    byte of the IP address (IP), Subnet Mask
    (SM), Syslog Server (LG), and Default
    Gateway (GW). You can also manually
    set the idle timeout period.
    Print an HP JetDirect configuration page
    to verify your settings. However, note that
    the print server might overwrite selected
    parameters with values that ensure
    proper operation.
    Table 27. EIO menu (continued)
    Select whether the Apple EtherTalk
    protocol stack is enabled (ON) or disabled
    (OFF).
    Faulty DFL-700 image - missing FWCore.cfg
    Possible problems:
    1. IDE Flash device is damaged
    2. IDE controller is damaged
    2. Firmware is corrupt
    Try and download the firmware, and install. You should then get a better idea if the IDE device or controller is bad if it won't install or see the device.
    Download Link:
    http://www.opendrivers.com/freedownload/232591/d-link-dfl-700-vpn-firewall-firmware-1.33su-download.html
    Top Sony Ericsson Cell Phones Experts
    Sean Wright
    Sean Wright
    Kolbrun...
    ZJ Limited
    ZJ Limited
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
