Dryers Logo
Posted on Dec 17, 2010
Hey I have an electroluc edc 5310 dryer, But today a weird problem happened. As soon as I start the cycle it stops and the light to empty the water container turns on. But the container is already empty, I tried turning it off and on again but didn't work. And if possible can you please provide me with the manual too
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
821
Points
Same problem happened with our machine.
Have you figured it out already? ;-)
Laz
  • Anonymous Dec 18, 2010
    We have the same problem with our machine.
    Have you already sorted it out? ;-)
    Laz
1helpful
Hey, i have a zanussi model zdc46130w. it stops drying after a few mins,and the "empty water tank" light flashes,even though the tank is empty?
the float down by the pump might be stuck......or the pump could be knackerd,................cheers
Jan 17, 2014 • Dryers
tip
OK I have now fixed my own problem with EDC 47130w dryer water tank problem.
The problem was the light to tell you to empty the tank keept comming on and the dryer would stop every 5- 10 mins and the tank always empty.It turned out to be lint blocking the tank fill area.
also some other problems with the tank and O"ring seals comming off.
I have made a video of my fix to share, here click the link to play the video.
I hope this may help. Please note this model looks the same as others so might be the same but different brand?.
1helpful
I have a 7 year old electrolux edc 5330 clothes dryer. The dryer seems to run normally - there are no weird sounds or error codes. However the clothes dry poorly. I have to run the most efficient drying...
Remove the dryer from the vent leading to the outdoors and try drying a load. This will reveal a restricted external/internal exhaust. If it dries in a normal cycle, it means the duct to the outside needs replaced or cleaned.If it still takes too long, the washer may need some maintenance to make it extract more water. If none of the above resolves the issue, the dryer will need to be disassembled inspected for worn, parts/air seals, etc. Follow the link below for disassembly instructions
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 20, 2017 • Dryers
I turn the dishwasher on normal wash and never stop washing i let it run for 2 hours and stiil running
Your dish washer probably has a "turbidity sensor". This is an infrared sensor that checks the condition of the water and adjusts your wash cycle accordingly. There is probably build up on the sensor (especially if you have hard water) and this is causing it to run so long. The easiest fix for this is to run a cleaning cycle on the dishwasher. Start your empty dish washer on a heavy wash cycle and wait for it to start filling with water. As soon as it starts to fill, open the door and pour 1/2 gallon of white vinegar into the bottom of the unit. Close the door and let it run its cycle. At the end of the cycle, run a second cycle and see if things improved. If things still are not better, you may have a bad sensor. If you have more questions, write me back. Hope this helps!
Dec 16, 2009 • Dryers
2answers
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Kenmore Model 24642300
It is usually a coupler, look under to see if black shavings
Water light on dryer
hey cadoras,
you might want to check the sensor for the water inside the dryer. you say that even if you already put water in it, the light is still on correct? which means that the dryer does not detect or sense that water is already there. so please check if the sensor is working and if not, replace the sensor.
33helpful
2answers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Top Electrolux Dryers Experts
vince
NOEL
NOEL
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
