Samsung YP-U3 MP3 Player Logo
Posted on Dec 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to install mp3 driver in my computer? - Samsung YP-U3 MP3 Player
Anonymous
Level 3:
  • Master 394 Answers
  • Posted on Dec 17, 2010
Anonymous
Master
Level 3:
Answers
394
Questions
0
Helped
96765
Points
1209
First you need to install the software for it (does not work on win7 so with win7 you cannot use it)
the link for both bits of software you need.
http://www.samsung.com/my/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=YP-U3ZB/XME&prd_mdl_name=YP-U3ZB&prd_ia_sub_class_cd=P
download and run them. the media studio program will then popup when you insert the mp3 player - if not us ethe manual to select that program manually.
let me know if this works for you.
How do I fix the driver for my Emerson mp3 player?
Hello
Try these links to download the driver for your MP3 player. After download the driver, install it to computer. Your device will be detected after proper diriver installation.
driver
Am trying to sync an album on to the mp3, but computer keeps telling me to connect devise, when it is already in the usb
THAT MEANS YOU HAVENT INSTALLED THE MP3 DRIVER IN THE COMPUTER. INSTALL THE DRIVER AND TRY AGAIN.
My computer cant recognize my mp3.problem with code 28?
INSTALL THE DRIVER FOR YOUR MP3 PLAYER .THEN YOUR COMPUTER WILL RECOGNIZE IT
Code 28 The drivers for this device are not installed. (Code 28)Recommended resolution
Install the driver
You may be prompted to provide the path of the driver. Windows may have the driver built-in. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. Right-click My Computer, and then click Properties.
  2. Select the Hardware tab, and then click Device Manager.
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to install the driver.
2answers
Computer says problem with new hardware when plugging in Sansa Clip MP3 player
Go to this link and select your unit in the download wizard and download the drivers for your device. Install the drivers without the Clip MP3 plugged in. Once the drivers are installed, you can then plug in the Clip MP3 and windows should correctly identify your new hardward and finish installing the drivers for it.
How can i install in on my computer
The computer must have a usb port before you can install the MW-3805 (128 MB) MP3 Player. Also the OS musthave the usb Driver for the USB Port. Insert the MP3 Player into the USB port and the computer is surposed to automaticaly identify the Player after few seconds. If the OS has a compatible driver the driver is loaded and your MP3 is ready for us. If the OS does not have a compatible driver, load the driver CD that came with the device when prompted. when the diver is loaded the mp3 will be ready for use.
Need Device Driver To Recognize MP3 Player
Look on the website of the manufacturer.
Installing mp3 playing on computer
you can download the drivers from sansa, downlaod.com, and many other sites carry them. They will need to be installed for pc to recognize the player
Music downloading problems
What kind of computer and what O/S ( windows, linux, 98, XP, ?) are you using? What make and model of MP3 player. To connect your MP3 player to your computer you need the right cable and the right drivers for the computer. Drivers are the translator program that lets your computer talk to the MP3 player. If they cant understand each other, no files will flow. Make sure you have the drivers for the MP3 player installed on your system and you have the right operating system installed in your computer. Good luck....Rob
COMPUTER INSTALLER DRIVER FOR IFP 780 MP3
my Rca mp3 player wont turn on even with new batteries
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
