If you want to Automatically send scan to the host then you need to go the Configuration Manager. Go to Scanner, Common, and then you will see Auto Send Scan. Change to 'Yes'. Then upload the termconfig by going to Wavelink Prod. Config and click on Application & Config.
does every barcode scanner can be set like this ?
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
SOURCE: my mc9090-g doesn't scan any barcodes
you can download MS active sync from microsoft website. then connect the gun to your computer to sync it. Once it sync, drag the barcode app to the windows folder in the gun.
SOURCE: i want to my m2004 to enter barcode scan after each scan automati
Print Adobe pages 128 and 129 of 302 of the M2000 Series Product Reference Guide and scan the "Scan Options" "Data Suffix" and "Enter" barcodes. The scanner will give two beeps after the first barcode, two beeps after the second and a warble after the third programming (Enter) barcode.
The manual can be downloaded from this link: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3969605apdf&sliceId=&dialogID=114420706&stateId=1%200%20114410949
