I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs real rough
Re: I have a coleman powermate premium plus 6250...
If you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Fresh Fuel Clean carburetor if stored with fuel in the tank and wasn't shut off Clean fuel filter Clean air filter Proper oil level Clean spark plug (just replace it, it is easier and faster)
Do check the oil after it has tried to start. Low oil cutoff would certainly cause the problem. Look for the "lost" fuel shutoff valve... there usually is one.
Your carburetor jet is likely plugged with varnish / wax from the old fuel that was allowed to sit in the carb. You will have to remove the carb, and clean it at very least. Since you already have to disassemble it, you may as well rebuild it.
Pull the starter rope and observe the ON/OFF switch. Does it flash as the engine spins? If so, you have found the problem! The flashing light in the switch indicates the engine oil is low. Add engine oil as needed to reset the AUTO-SHUTDOWN feature and it will run again. (If everything else is healthy.)
If this does not resolve the issue, reply to this post using the "Add Comments" option and we can further diagnose it.
Cbronson
how old was the fuel in the tank and carb bowl? This could have built up varnish and make the float heavier
Another issue that my customers bring in are 4 stroke generators that have 2 stroke fuel put in tank.
