The RAP does not lead you to the connector unless you trace the wiring in the BSD. This connector is located on an air duct on the bottom right hand corner of the IOT Drive PWB and acts as a double plug to connect on one side to the connector of the IBT Cleaner Blade home position sensor and the other side to a connector that leads to the IOT Drive PWB. After firmly plugging in the connector, the fault code went away. call 98413 40555
