Welcome to FIxYa.com what size engine do you have? Thank you for using FixYa.com Regards, Lee Davidian
Hello! I need a little clarification...When you give wire colors define if they are the vehicle's or the alarm...The vehicle wire colors for Lock/Unlock are as follows...Lock= Light Blue...Unlock=White
Constant +12 volts=Red...Accessory=Orange...Send a comment..Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Hello! The Flameout (FO) wire is the ignition power wire...On your truck it is a Pink Wire which is in the ignition harness...The FO wire serves two purposes...#1 it is the ignition kill...#2 the alarm module powers up this wire for remote start...One side of the FO Relay coil winding goes to ground...The FO wire connects to the other side of the coil...When remote start is activated the alarm module pulls the FO Relay via the FO wire...The objective is to enable or disable the truck's Pink ignition wire...This is the main power lead when the ignition switch is in start or run...If you cut the Pink wire and insert the normally open contact set of the FO Relay in series with the Pink wire, the engine enable/disable is controlled by the relay...
The only issue I am not clear on is the Orange wire that you mention...I'm assuming it is an Alarm Module wire...Can you identify this wire from the installation sheet?...Guru...saailer
Hello m1..... Here is the link to this alarm manufacturer including manuals, etc. If this site does not answer all of your questions, click on their contact icon and speak directly with their technicians. http://www.xlsperformance.com/cars_alarm_starter.htm
Joe
Thanks for choosing Fixya!
If you want my honest advice and thats not to bother with this as the amount of questions on here about cars with these sort of add things that go wrong after a couple of years and the owner is stuck out and cannot start vehicle .Or damaged remote or the recivers in the vehicle gone wrong ,if you need to then use the remote door opening part but do not interfere with the rest of it because at least if the remote door lock packs up which it will you can still use the key to open the door ,but the rest of the device ?? Better just installing a heater in the cylinder block that you plug in to keep engine warmish then at least the cabin heater will soon warm up quicker and the engine will start ,I have seen these here in europe but only a few and when i take vehicle for the annual mechanical inspection ,if they see it fitted then it has to be removed or the vehicle will not pass the inspection because its illegal to leave a unattended vehicle with the engine running .Well that my advice anyway ,the less things on a vehicle the better it is as less to wrong
When anything is "Negatively Triggered" this means that usually that, that Circuit, has a resistor of say 10K Ohms, to the Positive Voltage rail. To "Signal" that it is to be "Active: the Circuit is "Pulled Low" by a short circuit to negative/ground. This then gives a negative going signal, that's detected, and the Action performed.
Now usually any Inputs or Outputs have these Pull Up Resistors on the circuit board, and the simple grounding of the wire will "Switch" the Input. So to operate this we would install a switch, with one end on the wire, and the other end wired to the Negative/Ground, when the switch is tripped, it puts a short circuit on that Wire, and in turn, it will operate whatever is operated when that particular switch is tripped.
Most Often an Output is "Tied High" or left alone, as usually the "Logic: of that wire, High or Low, +Voltage or -/0 Voltage, is handled by the electronics internally. You can tell this by measuring the Voltage to earth when the unit is powered up, but not connected. High Out/in puts will have a +12 V voltage on it, or 0V on it. Toggling this line the "other " way activates that wire. If NOT used it is usual to "Tie them high" unless told otherwise.
All/Most Inputs and Outputs aren't needed for actual operation, and can be tested by Tying Inputs & Outputs high or Low, to activate or test a function...
A flame out relay, most likely wouldn't be used, unless you were wishing to monitor for Flame etc. (Sometimes used when running nitro)
Also I find a light bulb on the end of a pair of wires invaluable when testing inputs and outputs, using a small Bulb, you can use it to see an Output or to Trip an input and a visual indication is a lot better when testing
It seem that you do have a good understanding of whats going on, hope i haven't confused you too much and have been of some help..
I understood some of it. I got the lock and unlock to work. But now on the flame out relay, I should have said it is for, or being atached to ign 1.
I got the lock and unlock working. Now for the flame out relay, according to the diagram I have it is being connected to ign 1 but I don't understand whats going on here or how to connect.
Didn't answer anything.
I tried that a few times and never get a response
Wire colors are on the alarm. I tried to space and separate ever thing so it easy to read and understand but FIXYA keep combining the text.
I will get the colors and locations according to the manual tomorrow.
