MSI KM2M Combo-L (MS-6738-010) Motherboard Logo
Posted on Dec 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
None of the usb ports are not working. In the bios what should be enabled and what should be disabled.
Brian Sullivan
Level 3:
  • MSI Master 27,725 Answers
  • Posted on Dec 16, 2010
Brian Sullivan
MSI Master
Level 3:
Answers
27725
Questions
Helped
5664284
Points
79191
before trying anything in Bios
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
2helpful
2answers
Usb not working on desktop
Take a look in BIOS setting if USB ports are disable or issue with Motherboard
2answers
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Good day, we have a oki microline 3320 printer with a usb port. It is a new cable and we are trying to install it on our pc but it keeps on failing. Can you please assist us with this matter. many...
find out that any other device is working on that USB port? if yes then try with other cd, ask the dealer to provide u other cd. may be any file corrupted on that cd. if any device not working on that port may be the port is defective or may be it is disable from bios setting. go to bios setting while u turn on the pc see the message appears press DEL or press F12 to go to bios seeting. go to bios setting & find USB port is enable or disable. enable it.
1helpful
The usb ports will not work.
Chk whether the USB ports are disabled in the device manager by Right clicking on My Computer and then Manage and then Device Manager
If not disabled in device manager then chk through BIOS. (USB - Enabled or Disabled)
If not disabled then chk for any viruses in ur computer.
Tell me if not solved..
None of my usb ports work. Help!
  1. restart the computer
  2. to to bios setup
  3. enable the usb port  or use auto detect settings
  4. save changes
  5. restart the computer
Usb didnot work
go to bios and then perapherical setting there check usb port is enable or disable
if disable enable it
if u wanna go to a bios press "delete" button at start ur system
Tried to connect my usb card from my phone for pics. Suddenly, none of my usb ports are working at all. I am on another computer and my mouse and keyboard work just fine. It IS my usb ports. what could the...
It may be disable your USB in BIOS you should check the BIOS & enable USB in BIOS otherwise USB driver not installed on your system if driver issue insert the your Motherboard driver cd install the all driver.
I hope that this has been very helpful for you
2answers
The usb ports will not work,therefore the mouse nor the keyboard will work
Try the mouse in a computer where the USB ports *DO* work.
It is possible that your system does not have the correct "device-drivers" for the USB ports. Thus, those USB ports seem to be "dead".
Turn the computer off.
Connect a PS/2 keyboard and a PS/2 mouse.
Turn the computer on.
Click START
Click Control Panel
Click System
Click Hardware
Click Device Manager
Expand the "USB ports" section of the tree.
Look for "yellow" or "red" marks.
Double-click one of those "problem" devices.
Choose "Reinstall Driver".
If it asks to be able to connect to the Internet, click "yes, this time".
Hopefully, this will install the correct drivers for your USB ports.
USB ports do not work
1.) Check your CMOS/Bios settings to see if any USB ports are disabled.
2.) If not, check to see that USB ports show in your operating system's device manager or settings. Enable them if they are disabled. Otherwise, you may need to reinstall the drivers that came with your model of notebook computer.
If using Windows XP, for example, go to Control Panel, System, Hardware, Device Manager, Universal Serial Bus Controllers. If the latter is not present and you have USB enabled in CMOS/Bios, you will need to install the drivers. If "Universal Serial Bus Controllers" is present, look within to see if they are all enabled and working properly.
If not, re-install the drivers.
3.) If the above does not work, you may have bad USB ports that will require service by an authorized repair service for your notebook computer.
3helpful
Vista not recognizing PowerShot S30
1. connect U r camera to Back side Mother Board USB Port not for extension or front side port.
2. Check in bios USB controllers are enabled or disabled. if disabled enable it.
3. in windows device manger check for usb controllers
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
