defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
try reinstalling operating system from back up cd. If that do not resolve the problem, contact a good pc hardware engineer or chiplevel service engineer. They can solve the issue. Hope it helps
A pop is usually a power surge and you blew a board. If you take the tv apart, if this is it, it will be evident by the burn marks. You could have burned out the internal power supply as well.
You will have to plug it into a computer with an adapter to see if it is corrupted. MicroSD cards do fail sadly. If there is valuable information on it, a local computer company may be able to recover limited data.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Yes the display settings need to be reset since he had HDTV and you don't. I do this by simply having the PS off then press power button and hold it for 5 seconds.
