Master
- Posted on Dec 16, 2010
Re: I want to forward my faxes from my Panasonic machine...
Fax forwarding
You might want to set up fax forwarding if you are going on a trip, but
still want to receive your faxes while you are away. There are three fax
forwarding settings:
- Off (default)
- Forward-When your All-In-One receives a fax, it holds it in memory and then sends it to the fax number that you designate.
- Print and Forward-Your All-In-One forwards the fax to the designated fax number and prints the fax.
To set up fax forwarding:
- On the control panel, press Fax.
- Press Options until Fax Forward appears, and then press Select.
- Use the arrow buttons to scroll to the option that you prefer (Fax Forward or Print and Forward) appears, and then press Select.
- Enter the number that you want to forward the fax to, and then press Select.
Fwd now appears on the bottom left corner of the display.
