SOURCE: How do I adjust the flame on my Frigidaire model FGS383BADK stove?
its going to be listed in the installation manual ,not use and care, youre going to need to convert oven for lp gas. i would call the manufacture with the modelk number and ask for hte coorect conversin kit, for such a thing
SOURCE: I converted my 40
I am having almost the same problem. Frigidaire told me to replace all 5 mixing tubes, ~$385, yeah right. They don't have the orifices itemized as an individual part, so no-one carries them, just the LP conversion kit. Another repair/parts guy advised me to drill out the orifices. Some other threads/blogs give the diameter to drill. Basically, since natural gas is 0.5 psi, you need a larger hole than your current propane orifices provide. Please speak up if you find out anything, I will try to do the same. Good luck.
SOURCE: I have a Frigidaire Stove,
When converting an appliance from propane gas to natural sometimes a technician will drill the orifice to a larger size rather than replace the orifices. Either way is fine, but sometimes the orifices don't get drilled to the correct size. The regulator must be on the propane setting if it is a convertible regulator. If your oven is working fine.... the top burner orifices probably need to be checked that they are the correct size. A simple fix.
Tom
SOURCE: simmer flame to high
Tighten your spuds down with good fitting wrench till you get that flame how you like it. This video shows how to convert a stove from natural gas to LP gas. It shows you how to adjust them burners though. Take a looksee:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: I have converted my new frigidaire gas range to
What you do is tighten down the spud on the oven safety valve.
Get a good wrench and in the case of propane or LP you tighten down clockwise on that spud. Then open the air shutter all the way.
