Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Here is a video to walk you thru the process.
Although the
two names of drinks are used interchangeably, hot chocolate is a drink that's
either made from real chocolate melted into milk or with packet hot chocolate
powder. Cocoa powder is unsweetened and needs to be combined with sugar to
create a sweeter drink.
In general
hot chocolate is richer and sweeter than hot cocoa.
