Panasonic CQ-VD7001U Car DVD Player Logo
Posted on Jul 01, 2008
E1 Error on Panasonic CQ-C1110W Car CD Player
I recently bought a second hand Panasonic CQ-C1110W Car CD Player.
installed it and radio works fine but won't play CD.
I tried cleaning with CD cleaner but still the same problem.
Maybe it need some kind of code to fix the error.
Some one with the same model can help, or if anyone is able to help.
Cheers,
Jex
  • brent Sep 09, 2008
    I have a CQ-VD7001u car DVD Player and when i try to play a cd it come up with E1 error. i put in a brand new cd and it still is doing the same thing. does anyone know what the E1 error is?
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on May 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
6755
Points
23
If you receive an error reading or the cd ejects automatically briefly after being inserted, the headunit needs to be repaired or replaced
Can not save radio stations
what you need to do is check to see if your radio is connected right ......
in the installation of any radio in a car or truck there is a yellow wire that is constant power that save memory and the clock without this wire getting 12volts all the time you will not be able to save station to the radio if you set them everytime you turn off your car or truck they will go back to factory preset .... now once you find out if the constant power wire has power and you can say that is not the issue i would call panasonic and find out a service center near you and have your radio fixed ...
http://www.tintingbyfredjohnson.com
[email protected] Hi there. I just recently bought a PANASONIC CQ-C1323NW for my car 2nd hand of my cousin and for some reason it just doesnt seem to save any of the settings a apply to it eg radio...
There are two battery supplies to your radio.
The main one via the Ignition Switch
The permanent one to feed + retain the memory...so this one is missing
Check the wiring, connectors + fuse
It wont play cd just keeps saying e1 eject cd radio plays fine
look for areset botton if it dosent have one by a cd cleaner if after that its the same replace the radio
Please help me fix this problem
At electronics stores you can buy a CD player cleaning kit that includes a disc you put into the player that is designed to clean the lens. Since the lens in most vehicle CD players is fairly inaccessible, that may be your only option.
Panasonic CQ-C700U
Sorry, there's no way to repair the CD, if faulty. Try looking for a "reset" a VERY tiny hole somewhere behind the "door", on the face of the radio chassis...Using a paper clip end push into the tiny hole for a few seconds, ignition/radio on...If you can't find a reset...take it to a friendly local car stereo shop and ask them to diagnose the problem ($40).
Good Luck
1helpful
Preset channels on Panasonic car radio out of tune
this is simple enough to do, just find the channel you want to save, then press and hold a number u want to save it to!
i.e No. 1 - 96.9Fm
hope this helps
1helpful
How do you store the radio stations on panasonic cq-c3100vn
Just select the station you want to store and press and hold it for few second the number where you want to store it.(1 to 6)
3helpful
Panasonic cq-c1323nw reset button
hi there type your model number into this link and you can download the user manuall, i've tried it for your model no and it works.
http://www.panasonic.co.uk/html/en_GB/220239/index.html#anker_220239
TOC reading... e1 error
Buy a cd cleaner kit, if it doesn't work have some one capable re-align you laser len. When the unit get use for times the len got tired(worn and mis-align). Goodluck.
2answers
No sound from CQ-1305U car CD/stereo
You may have one of this two problems:
One of the speaker wires is grounded to the chassis.
Or your car may have a factory amplifier between the radio and the speakers.
My suggestion is to rewire the speakers lines
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
