Yes you can connect HP Officejet 6210 All in One printer to your PC using USB Cable.
You need the Software to install.
Click on the Download link below to download the printer software/drivers If you don't have software disk.
Choose the operating system to download the software.
Download Drivers
Instructions :
Disconnect the USB cable before Installation of Software
Download the software and run the file to start installation
At a particular point, it will prompt you to connect the USB Cable to PC Port. ( Make sure the Printer is Powered On )
Continue to complete the installation.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Click "Start" and type "wireless assistant" into the search box.
Click the "HP Wireless Assistant" entry in the list of results.
Locate the "Bluetooth" entry.
Click the "Turn On" button in the "Bluetooth" category to enable the Bluetooth antenna in your HP Pavilion.
Hope this helps
You can use the wireless button or HP Connection Manager (select models only) to turn on and turn
off wireless devices.
NOTE: A computer may have a wireless button, a wireless switch, or a wireless key on the
keyboard. The term wireless button is used throughout this guide to refer to all types of wireless
controls. Refer to the Getting Started guide for information on identifying the location of the wireless
button on your computer.
To turn off wireless devices using HP Connection Manager:
? Right-click the HP Connection Manager icon in the notification area, at the far right of the
taskbar, and then click the power button next to the desired device.
- or -
Select Start > All Programs > HP > HP Connection Manager, and then click the power button
