Humidifiers Logo
Posted on Aug 10, 2017
I have a Holmes humidifier. Model # HM 5601. I have cleaned tray with the solution I purchase with it. I filled it and turn it on low to start with low output of humidity and it keeps shutting down. the reset button illuminates and has not even slightly put out any vapors. I have had this for three years and last year it worked. Is there anyone who can help me figure this out please? Thank you!
5 Related Answers
Anonymous
  • Posted on Mar 27, 2009
SOURCE: Holmes HM5601 quit working
I had the same problem with my Holmes HM5601 humidifer unit - right out of the box. I almost returned the unit to the store, but was able to figure-out the problem. Not enough water had been filling the heating section (where that black knob-like protrusion is) and the lack of enough water had caused the unit to shut-off soon after plugging it in. The problem is in valve at the bottom of the water tank! The valve is a factory defect. It needs to open more when you sit the water tank onto the base so water fills the reservoir. I had solved the problem by going to the hardware store and purchasing some small, rubber pads or feet. These rubber pads are the type used to place under things where you want to protect a table-top from being scratched or you want the item not to slide too easily on a table-top. These rubber feet or pads have an adhesive on the bottom of them. Find the size that matches the diameter of the valve stem on the bottom of the water tank. Once installed, the valve should open and close with your finger without the rubber pad interferring with the operation of the valve. The pad, if installed properly, makes contact with the water reservoir base when you placed the water tank down onto that base. The valve open a bit more allowing water to pass-thru and fill the water reservoir. Water fills the heating section as needed and the unit runs perfectly after! The round rubber pad I had used was about an 1/8 inch thick and 1/2 inch in diameter.
Anonymous
  • Posted on Jun 04, 2009
SOURCE: humidifier doesn't stop
I had the same problem if you dissasemble the unit you will probably find a capacitor between two blue wires has blown out
Anonymous
  • Posted on Dec 16, 2010
SOURCE: Honeywell Natural Warm Moisture Humidifier Is On But No Steam?
I have the same problem and I have 2 of them fairly new. I can't seem to find out what the problem is either.
Stumped?????????
Sparky2012
Sergio Shamshoian
  • 102 Answers
  • Posted on Jan 15, 2011
SOURCE: The humidifier says "desired humidity" when turned
I would say, either the humidity level in the room is hi or the humidifier is defective, In my house the humidity is about 42% to 45% when we use the humidifier, and can drop to 30% or less if we don't, we leave in DC area,
I hope this helps.
Anonymous
  • 4736 Answers
  • Posted on Aug 26, 2011
SOURCE: How do I clean my
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Hope this helped you and thanks for choosing FixYa.
Here is all the info I found Ser # 50908272 Holmes Humidifier HM-300
It depends on how humid it is in the conditioned space, how well sealed the conditioned room is, and how high you have the humidifier set. If you have low humidity in your conditioned space and you are asking for a higher humidity number, it could go through quite a bit of water. If your room is not sealed well, it will allow lower conditioned air into the room and put a larger demand on the humidifier
Jan 21, 2018 • Humidifiers
How do I clean my humidifier Holmes hm 500? I don't have the manual anymore. Thank you! Jaimee Murphy
I HAVE A HM 5700 HUMIDFIER AND NEED A NEW CAP FOR THE TANK CAN YOU HELP ?
I ordered 2 replacement caps from here they were the cheapest tat I found http://www.jardenstore.com/productdetails.aspx?BrandId=494&pid=1783 but they seem to be out of stock at the moment These http://www.appliancefactoryparts.com/humidifiers/holmes/holmes-water-tanks.html are 3 dollars more here hope this helps
1helpful
We have an HM 1740 Family Care humidifier. The reservoir filler cap is broke. Can I get a replacement? M. Frauwirth
Hello! I found this link where you can buy the filler cap for $6.99. I hope it's still available!!!
http://www.appliancefactoryparts.com/humidifiers/holmes/hm1740.html
Holmes HM4600 Humidifier LEAKING - - HELP
well since you just purchased this item, you should be able to return it for exchange, and it should still be under warranty, but if thats not doable, then it sounds to me like its a O-ring that is bad if the tanks are removable, best bet though is to exchange it, look at your home owners paperwork, to see about the warranty, more than likely your covered, hope that helped,
mr.grzz
Cleaning water tray
I usually just balance the tray upside down on top of the base and fill the edges with vinegar. You could also put the the tray in a bowl filled with vinegar and submerge the whole thing.
Top Holmes Products Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
