Acu-Rite AcuRite 00592A2 Wireless Humidity and Temperature Meter Logo
Posted on Dec 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Time keeps changing on its own, going back 1 hr. to a different time zone. How do I remedy this? Thanks
Anonymous
Level 2:
New Friend:
  • Expert 100 Answers
  • Posted on Dec 16, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
100
Questions
0
Helped
26363
Points
251
Check to see if clock is set for daylight saving,
also check that your correct time zone is set
How do I reset the time on my Fitbit watch
Here is the way you can reset time on your Fitbit without Reset Fitbit Charge HR -
  • Open the Fitbit app on your phone
  • Then Go to the Advanced Settings
  • Now turn off automatic Time Zone
  • Press Select Time Zone
  • Choose the time zone according to your country
  • Synchronize your Fitbit to your smartphone
The Guide Of Reset Fitbit Charge HR Complete Guide
Oregon scientific instructions
Which model Oregon Scientific do you have? There are a couple that you need to set the time zone with a switch on the back of the unit. For the BAR388HGA-BK, you press and hold Mode for 2 seconds until it goes into the setting mode. Then you can use the up/down arrows to cycle through the Time Zone options. (1 is Pacific, 4 is Mountain). Press Mode again to confirm the setting and advance to the next item to change. You will leave the Set mode if you do not press a button for several seconds. If you just press and release the Mode button, then you can set the time display option.
A number of Oregon Scientific product manuals are available here:
Technical Support , http://www.oregonscientific.com/us/en/service/support . Scroll down and see the drop-down menu on the right.
I hope this helps.
Jan 25, 2014 • Garden
Set 24 hr hand
first click changes the date if you turn one way, but turning thr other way should change the 24 hour hand.
Nov 30, 2009 • Watches
1helpful
MY DESKTOP TIME IS IN 24 HR FORMAT
START->CONTROL PANEL->DATE,TIME,LANGUAGE.....->Change format of numbers,dates and time. Under regional and language option click customize option and select time tab under customize regional options . There would be an option to change date, time change format. Click that and it would fix the issue.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
9helpful
2answers
Changing from 24 hr system to 12 hr system
  • Press "MODE" (lower left hand button) three times to get to the screen where the numbers are blinking, indicating that you can adjust the time
  • Make note of the hour if you don't have another clock handy
  • Press "LAP/RST" (lower right hand button) once to get the hour numbers to blink, indicating that you can change them
  • Press "ST/STP" (upper right hand button) to move the hour forward until you go past 24
  • At this point, you will notice a little "A" next to the time to indicate AM, and if you keep going past 12 hours, it will cycle back to 1, this time with a "P" next to it to indicate PM
Clock not keeping correct time
The CMOS battery keeps the laptop configuration stored in the CMOS chip and the main battery has no effect on the CMOS.
If the date and time drift off, it indicates the CMOS battery is nearly flat and needs to be replaced.
If you had ticked the Daylight saving box in the Time Zone tab in Control Panel - Date and Time setting then the time would automatically adjust for Daylight saving.
3helpful
Time not correct
press mode button once.
Then press set until the time zone is on the correct setting
then press mode again
56helpful
9answers
IPhone sync with Outlook Calendar - Appointment time put on iPhone 1 hr later.
This solution pertains only to the one hour time difference people notice upon syncing to MS outlook.
In iPhone, there are two areas where you have an option to change your time settings.
1. When you go to 'settings', then to 'general', you can set up time and date, and also 12-24 hour format. Please note that changing the time here DOES NOT correct the problem, despite iPhone displaying correct date, time and time zone. Many people in this thread have stated that the problem persisted despite them setting appropriate time zone.
2. When you go to 'settings', then to 'mail, contacts and calendars' row (NOT the 'General' row) - you get an option to change your time zone at the very bottom of all the choices. You will see that wrong time zone is selected here - likely cause of the problem. Correct this choice and the one hour discrepancy between appointments in outlook and iPhone disappears.
Additional problem solutions - in the solution No. 2, if you set 'Time Zome Support' to 'ON', then all your appointments in the calendar will be displayed in the time zone of your HOME address. In other words, for example, if you are a person in central time zone, your appointments will be displayed ALWAYS in central time zone format - they will NOT change automatically when you travel from central time zone to eastern time zone. On the other hand, if you set the time zone support to 'OFF', then all your outlook appointment display times will change and adjust according to any time zone you travel to - This is often an inconvenience since most of us would like to remember our appointments as they were made in our home time zone, regardless of what time zone we traveled to.
Please note that the above solution pertains to only display of appoint times in outlook - This solution does NOT relate to the time displayed by iPhone and how that displayed time adjusts when you travel to different time zone away from your home time zone. This second issue is addressed below -
You can get your iPhone to display the current time in two ways -
1. Either always show the time in your home time zone, regardless of where you are (i.e., a person from Texas central time zone can set up to see the time always in central time, even if he/she travels to another time zone). This display setup is good for people who always think of time in their home time zone and then do mental conversions to reach at the local time zone time.
2. On the other hand, you can get iPhone to do this for you and change displayed clock time automatically to the local time zone that you have traveled to, away from your home time zone. Please note that enabling this capability in iPhone has no bearing on how the appointments are displayed in MS outlook.
Go to 'Settings'. Go to 'General' tab. then click on 'date and time'. Pick the 'set automatically' option to 'ON'. Now, the iPhone will automatically adjust displayed time to show the current time in which ever time zone you travel to.
If you set the 'set automatically' option to 'OFF', then you can select your home time zone. Then, the iPhone will always display time in your home city time zone and will NOT change even if you travel to a different time zone.
So, in summary, there are two places you need to adjust the time zones in iPhone - to do two separate tasks, first task of displaying appointments always in your home time zone upon syncing with outlook thereby avoiding the one hour skip; Second task of getting iPhone to display either your home time zone clock, or getting it to adjust current time to reflect the time in new time zone you travel to.
Hope this helps.
58helpful
3answers
Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Top Acu-Rite Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
