If there are lines through your line appearances than your phone is likely not properly registered with your Callmanager or SIP registrar, you need to configure your phone properly so it registers and associates with an extension on your PBX or hosted service.
can you explain me how is your phone connect to internet. best on your Question its seems to me you cant hear a dial tone because of following one or more factors might apply
you must log into the Extension Mobility service
you must enter a client matter code (CMC) or forced authorization code (FAC) after dialing a number
your phone has time -of-day restrictions that prevent you from using some features during certain hours of the day
The handsets will eventually go bad. If it is every single handset that you have, the problem is with the system. But if the problem is only with a few of your phones, you might consider replacing the handsets. We at IdacomUSA.com have replacement Cisco handsets for sale at only $25. Hope this helps you out :)
It sounds like you have enabled Do No Disturb accidently. This can be turned on and off by pressing the DND softkey button along the bottom of the LCD display. You might need to press the 'more' softkey to display all options.
