SOURCE: i cant find the filter on the hotpoint aquarius wd440
Depending on which model you have ,there are 2 possible locations for the filter.
Check to see if there is a removable plastic panel at the botom front of washer, if there is then remove it and if there is a filter there , you will see it, unscrew the cover anti clockwise and clean same.
If no filter there then remove lower rear panel of washer,locate large black hose, and remove clip and hose from bottom of tub,be careful as there will be some water run out.
Remove plastic filter and ball ,clean and replace, and refit hose, making sure it is secured properly.
Test for leaks.
Plz rate my solution.
Thanks.
SOURCE: hotpoint aquarius extra wma46
The first question you need to ask yourself is, "is the drain pump running?" If you can hear the drain pump running when it tries to drain, then more than likely you have a clogged drain pump, or drain line. Here's how you can determine which one: You can check the drain line by seeing if it collapses when the pump starts to run. If it does, then you know you have a clogged line somewhere BEFORE the pump. This usually means an article of clothing has gotten between the wash basket and outer tub and is stuck in the line. If the line is full of water and doesn't seem to be going anywhere, hook up a wet/dry shop vac to the drain hose in the rear of the machine to see if you can pull water from the tub, through lines, and through the pump. If you can't, you know you probably have a clogged pump, or drain line AFTER the pump. If the drain pump does not come on, you may have a pump failure. In either case, you need to drain the water from the tub. A wet/dry shop vac does a great job at pulling water from the tub, so you don't have to bail. Let me know if this helps.
SOURCE: stale water smell
If the washing machine itself smells bad when you open the door, it could be that it's covered in a horrible grease and gunge inside all the hoses and the tub. This particularly affects older washing machines and is common with washing machines that have only really been used at 40° or where only liquid detergent has been used.
Not using enough soap detergent over a long period of time can cause a build up of grease and therefore bad smells.
Get rid of washing machine smells
You could try to clean the washing machine inside using Soda crystals which dissolve grease. I recommend putting half a packet inside the drum and washing on a boil wash (or follow instructions on the packet) Using this method every month or so, or using ordinary detergent if no soda crystals are available can help prevent smells from your washing machine. If your washing machine is badly affected by grease and slime, it may be very difficult to remove it.
Get rid of washing machine odours using vinegar
White distilled vinegar has an array of uses. For bad washing machine smells, try putting half a cup of white vinegar inside an empty machine and put it on a boil wash. Because the first bit of water goes into the sump hose and is sealed off, I recommend that you wait until the washing machine has been filling for about 30 seconds and then pour the vinegar into the soap drawer to let it wash down into the machine. I've had reports back from people that this does actually work.
SOURCE: does machine have a filter
The filter is to be found at the rear of the washer.
Remove lower rear panel of washer, remove large black hose fastened to bottom of tub.
Watch out for water running out.
Remove plastic`filter inside hose and clean.
Refit filter and hose.
Dirty washing can somtimes be attributed to washing at too low a temperature, so make sure you have selected right temp for washing.
Please leave a fixya rating for my solution.Thanks.
SOURCE: Where is the filter on the Hotpoint Aquarius
Filtet access at the rear of the machine behind access panel, Remeber to remove the plug from the socket before removing the rear panel
