I sat on my navman and broke the LCD touchscreen.
Can I buy the screen and install it myself without paying heaps of money for somebody else to connect it up.
Thanks, Ollie.
I have seen this with cameras, and pocket TV sets.
It is best to send the unit back for factory service. Ask for an estimate before servicing.
The parts in your GPS are not generic parts. You can buy the screen from the manufacture and find that the circuit board under it is also broken or damaged.
You may also find that the cost of the screen replacement may approach the cost of a new unit. I have seen this on many small devices. In some models the screen module comes as part of a complete matched assembly.
Are the stripes like pixely (sharp stripes) or blurry (from background)?
You might have damaged the edge of the screen where the connections are and broke connections. These types of problems are impossible to fix. You need replacement panel witch can cost a lot. Cheaper is to buy new model. You can re-sell the screen motherboard, PSU as those are sometimes valued replacement parts for screens that have working panel but broken circuits.
Another tip for you is to find a exact same screen with broken circuits and replace those. I have found myself broken screens just for cents.
Maybe Cracked screen???
If broken, the screen is just like cellphone screen, digitizer is also broken and screen won't respond to screen touches... Find a trained repair shop. EmbroideryServices
Hi there, I now have two Cybershot DSC-T10 with broken LCD's. The best remedy that I have found is buy a parts camera with a good LCD on EBAY. You can get the whole camera for way cheaper than you can buy a new LCD.
The screen of the a1000 model is composed of 2 parts, the lcd display and the touchscreen pannel wich are both secured in the same housing, protected by a metal frame. Even if you only broke the lcd screen (and the touchscreen is still ok) in most cases, a service center will replace the entire screen assembly. It will cost somewhere around $100-200 depending on wich service center you choose. If you try this operation in a service center, the costs will be greater because you will buy a new screen and pay the labour part. It would be greater if you can buy a second hand broken a1000 with a good display and change it yourself. A1000 and the P9xx series are very easy to dissasemble and work with. You may receive further informations and pictures if you reply with this request.
The short answer would be to try to avoid a service intervention to the phone. It will be very expensive. the a1000 model was made in 2003 so the spare parts that can be found today are expensive and hard to find. Try finding a second hand unit, you may strike a good deal with it.
contact canon in aurora illinois they might be able to help you they do factory service and refurbishing so they might have the part or be able to point you in the right direction.
There is no need to replace the whloe lcdscreen, you just need to replace the touch screen & panel which is a thin glasstop on the top of the lcdscreen. The whole lcdscreen is expensive, while a touch panel is much cheaper than that.
And we could provide all kinds of PDA accessories.
Here are some information for you
In general, PDA LCD screen comprises the touch screen. LCD screen acts as a display of PDA or SmartPhone, and the likes, which cannot go without LCD screen.
Touch screen is short for touch screen digitizer which seizes the upper part of PDA LCD screen. It is pressure-tactile, runs with gentle touch of stylus, finger and other tele-pointing function-possessed device. Different
from LCD screen, the touch screen is an optional component for PDA,
SmartPhone, and the likes. A PDA can function well even without the assembling of a touch screen for the availability of keyboard.
