To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
The unit has 2 alarms (alarm 1 and 2). They can be used
together or independently. Alarms 1 and 2 have different
sounds so that you can differentiate them. The alarm will
sound for 1 minute unless it is disabled.
To set the alarm:
Navigate to "Set Alarm" setting mode as shown in the
Changing Settings section. The order of the settings is;
alarm 1 or 2, hour and minute.
To enable or disable the alarm:
• Press MENU until you reach alarm 1 or 2 display.
• Press [UP] or [DOWN] button to enable or disable the
alarm. "-:--" means disabled.
OK.
