Hi vne.... Generally there is a set screw in the handle, under where you grab hold of it. You will need an allen wrench set to find the right size for this job.
Once you have the handle off, turn off the water to this faucet. Important step.
Once the handle is off you will see the nut holding the cartridge in place. You will need the proper size wrench to get this off. Remember "right is tight and left is loose".
Joe
Thanks for choosing Fixya!
From www.hamatusa.com
Turn off water at supply line. Turn and remove top ring. Remove handle. Remove top half of body of faucet. Remove diverter (using large screwdriver) and replace. Replace body handle and ring.
Let me know if this works or not.
Gary
How do I remove top half body?
Not sure if I sent this message!! How do I "remove the top half of the faucet" to get at the diverter?
Thanks
