Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250 Logo
Posted on Dec 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace the oil pump on a Stihl MS170 chainsaw
Joseph Mueller
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 346 Answers
  • Posted on Feb 11, 2011
Joseph Mueller
Expert
Level 2:
Mentor:
Answers
346
Questions
Helped
171854
Points
784
The oil pump is pressed in from the bottom. There is a special bolt and bracket to make sure the pump is set to the right depth. Your local dealer should bea able to get the tool for you but it will be cheaper to have the shop do the work.
PS it is more common on this saw to have a dull chain act like it is not getting enough oil than to have a bad oiler.
I am gold certified and have been doing repairs since before the ms series. I have only replaced two oilers in that time.
Good luck
JOE
www.arcolawn.com
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
2answers
How do i replace piston rings stihl ms170 chain saw
Part 4: Stihl chainsaw piston and cylinder replace / repair ...
? 13:54
https://www.youtube.com/watch?v=jCbMCkGqCIQ
Dec 15, 2011 - Uploaded by Andy Reynolds
Refitting the cylinder to the rebuilt crankcase on a Stihl 026 chainsaw. ... Part 4: Stihl chainsaw piston and cylinder replace / repair. .... Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings - Duration: 15:10.
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti ...
? 15:10
www.youtube.com/watch?v=n9RbtjNc-nc
Dec 16, 2011 - Uploaded by Andy Reynolds
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings ... Part 4: Stihl chainsaw piston and cylinder replace/ repair.
How do i find a repair manuel for stihl ms170 chainsaw
Best Advice I can give you is to contact Stihl directly on their website or 800 number.
Model number stihl rollomatic mini user manual
855-456-4299 try this#
http://www.hlsproparts.com/stihl-replacement-parts-s/79.htm?Click=28651&gclid=CNXP0_WbmcQCFQsxaQod1XgAug
Will a stihl chainsaw engine assembly from 017 fit in a ms180
those saws are part of the same family so there should be no problem putting the two together
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
MS170 oil pump. I have investigated it. Worm gear was worn, repl'd it, pump is turning but no oil out port.
The filter in the oil tank may need to be cleaned.But you will most likely will have to replace the oil pump and it will have to be done at a stihl dealer. It requires special tools to remove and replace. George
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
