SOURCE: replacing the starter on my 2005 Kia Rio
1st disconnect your battery
(Tools that I needed. 14mm socket for mounting bolts, 13 mm socket and a drop light. You need to jack up the front end pretty high both sides and put jack stands under each side. (extra precaution I put wood under the wheels because I don't like getting crushed. Slide under your car (bring a drop light) Look up and see your oil filter. Now look left and you will see the starter motor (oh yeah there is a pain in the as s bracket in the way) remove that bracket (14mm should be right) and then remove the bottom bolt of the starter (you may need a long socket extension here 8"?) The next set of bolts you have to get from up above that come from the other side. Get your light in there the one on the left side is easiest so get that last. The one on the right side will have a wiring harness running really close to it. Force your 14mm socket onto it with a 4 in extension. Back the bolt off till it spins a free but leave it in the hole. Remove the second one until you hear the unit fall. When putting the two bolts from the other side in, don't reef on them to get them super tight. Save your core so you can get some money back. Good repair manuel will cost 20 bucks, Haynes auto repair at your local auto parts store. good luck
Testimonial: "Fast Comeback. I think I will become a member here."
SOURCE: 2007 kia rio - owners manual missing
check this site
http://manualspace.com/kia-rio-rio5-2008-owner-s-manual.htm
SOURCE: I need a diagram of
They should be marked on the coils... You could also just match the cables by the length.. Please let me know if this was helpful and if itsolved the problem and good luck..
