Master
- Posted on Dec 16, 2010
Re: I just installed a Kholer Rialto toilet and the...
My toilet is running, how do I fix it?
To solve this problem, you'll want to ask the following questions:
- Is water running into the overflow tube? If so, lower/adjust the float valve. By doing this it will float higher closing the inlet valve.
- Is the chain too slack or too tight? Make sure the chain has only 1-2 beads of slack.
- Has the water in the home or surrounding area been recently shut off for some reason? This could cause debris to come up through the water pipes and settle into the diaphragm seal of the fill valve. Flush out the diaphragm seal.
This is not an unusal problem; here is a video that may provide more assistance:
