Hey G,
This bit set has all the "special" safety bits you need... I have one and its always had what I needed..(even has the reverse three blade phillips head.. - they use them on police monitoring ankle bracelets) ....you will need a driver handle..
good luck..
100 Pc Security Bit Set with Case
SOURCE: cuisinart frozen yogurt and ice cream maker.
I found the complete manual at
http://www.pickyourown.org/icecreammakermanuals.htm
It has not only instructions, but also a lot of really cool suggested recipes.
SOURCE: I lost my instructions for
Hi - You can download the manual from the link below:
Cuisinart
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: cuisinart Pure Indulgence ice cream/frozen yogurt and sorbet maker (2 qt)
Instructions can be found at the Cuisinart web page. Here is the link: http://www.cuisinart.com/manuals/index.php?item_id=423
SOURCE: ice cream is soupy & when I freeze it it becomes icy
Freeze the bowl for at least 24 hrs, rather than the 12 hrs the manual suggests - it will make all the difference in the world. For really thick ice cream, freeze the bowl for a day, and then put the ingredients in the freezer until the outer rim becomes frozen. Very delicious!
-Tha Mp3 Doctor
Were you able to get that last screw removed ? I'm in the same camp and came across you're qquestion with no good answers.
Also in the same boat. Curious to hear your solution.
It is the flat blade screwdriver that is notched out in the middle of the blade. You could even get a cheap screwdriver and dremel a notch in it.
