Sounds like the switch that controls the blower is faulty. It should heat up then come on at preset temp. As for the stat where is it located. It should be located 60" off the ground not in any direct sunlight and make sure it is insulated behind the stat. You could have more heat loss in those rooms too. IE poorly insulated windows air penetrating through outlets do those walls face the wind? Is the stat located next to a heat supply?
Testimonial: "Thank you! I will look into getting the switch checked and verify the stat location. I appreciate your assistance! "
