Question about Jaeger-lecoultre Compressor 1728470 Wrist Watch
How do I replace the watch bands . Thank You - Jaeger-lecoultre Compressor 1728470 Wrist Watch
  • jim dimeo Dec 18, 2010
    Not correct, on the bottom of the watch there is a switch that pushes holder in and out I need help with how to work it?
    Genius:
  • 1,417 Answers
Repairing a watch band sounds like a task for a seasoned professional. But fixing the band on your watch isn't like taking apart your watch and performing surgery. It's actually a fairly simple process.
Instructions And Materials Needed Below.
  • Spring bar tool,Round-headed pin,Calipers,New watch band
  1. Measure your old band. Find out the length in inches, and, more importantly, the width in millimeters at the ends that connect to the watch body. Leather watch bands may be measured in inches at the connecting points.
  2. Choose a new watch band that matches your measurements. You can choose between leather, plastic or metal. Metal bands come in standard links and the self-expanding type.
  3. Remove your old watch band. Many replacement band kits include a spring bar tool, a tiny bar that looks like a screwdriver with a wrench for a head. The purpose of this tool is to slide into the space on either side of the bar that connects the band to the watch. This spring bar telescopes out at either end to fit into holes on the watch body. Use the tool to compress the bar until it is short enough to pop out of the holes that hold it in place.
  4. Clean the connection points on the old watch body. The holes that hold the spring bar ends are called lug holes. Grime collects in these holes as you wear the watch. Clean out the lug holes with a round-headed pin.
  5. Install the new watch band. Slide one side of the spring bar into a lug hole. Push the band snug against that lug hole. You may be able to slide the bar into the opposite lug hole. If not, use the spring bar tool to retract the bar on the opposite side. Then slide the bar into place. Repeat for the other side of the watch.
  6. Adjust the length of the band. A leather band may need more holes at one end or the other to fit comfortably. Professional watch repair companies use a staking tool with a concave point, making a clean cut with no ragged edges. A metal band may need links added or removed. Links that are held together with pins need a special pin-removing tool. Links held together with clips are usually separated with clip-removing pliers. Both these tasks are most easily accomplished with help from your local jewelry or watch repair store
Good Luck and thanks for using fixya.
Posted on Dec 18, 2010
  • 40 Answers
You'll notice that the band, between the 2 fingers of the watch, is held by a pin. That pin has a very small head, like a nail. With a very small flat screwdriver, (jeweler type), simply get between the finger of the watch and the head of the pin and slowly try to disengage the pin. Push it to the other finger. (be careful as to NOT drop the pin as they are spring loaded
Posted on Dec 16, 2010
SOURCE:
Suunto X9 replacement band
looking for a replacement wrist band for my watch
May 23, 2012 | Suunto X9 SS004729320 Wrist Watch
Where can I get a new band for my KS4003 Kenneth Cole watch? The clasp won't open and I didn't want to pay $65 just for a new clasp. How much is the band?
Thank you for contacting FixYa,
You can contact Kenneth Cole for a replacement band but I am afraid the band is probably going to be alot more then the $65 for the clasp. I would honestly just replace the clasp unless the band is worn in which case I would do the band.
Sorry.
KC can be reached at 1-800-KEN-COLE
Oct 02, 2010 | Kenneth Cole Watches
I have a Woman's Mickey watch that has "Disney Time Works" on the back of it. I would like to get a new band for the watch since after 10+ yrs it is very worn. The band is gold tone but it has not the...
mcdevito75 here, Any small watch repair shop can replace the strap for you. Ebay may have Mickey Mouse replacement straps if you"d like a Mickey Mouse strap.
Sep 24, 2010 | Disney Watches
10L02 Wittnauer watch~need band screws that connect link to link
If you can get to a watchmaker or even one of those watck "kiosks" where they mostly replace batteries or even a jeweller they may have what you need.
Jul 18, 2009 | Watches
Watch band problem (Technomarine RSQL01)
Do you know no one takes proper responsibilities about electric item, but you should need to check once so Oniline sites are good because you can get a new stack watches. Top Seller of Week 10 Discounted Watches 24 7
Jun 23, 2008 | Watches
Where can i get a replacement watch band for my shark x freestyle watch? thanks.
Here is the link to their customer service page:
http://www.freestyleusa.com/contact.php
Call the Warranty/Parts and Repairs number on the left and they should be able to send you a new band to take to a jeweler to replace, or you can send it to them and they will fix it for you (with 4-6 week turnaround, however).  I got a 75003 watchband replaced, but I imagine you can get every band replaced.
Jun 03, 2008 | Freestyle Shark Buzz Wrist Watch
Oakley band/strap
I called Oakley customer service and they said mail in watch and they will put on a replacement band for 45 bucks
Oct 28, 2007 | Oakley Detonator OAK0530 Wrist Watch
Jaeger-lecoultre Compressor 1728470 Wrist Watch Logo
151 people viewed this question
Top Jaeger-lecoultre Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Jaeger-lecoultre Watch Expert? Answer questions, earn points and help others
