Paragon 4004-71 is 240Volt timer
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
1) If your trippers are worn down, the timer will not turn on and off
Google search for X2772 trippers.
2) If your timer dial is not rotating, then timer clock motor is bad.
3) According to e-mail I received from Paragon Nov 2010, Paragon is no longer making timers and parts, except for their line of defrost timers.
4004-71 is not a defrost timer, so it is no longer being made according to Paragon representative.
4) To change timer brands: Intermatic cross reference shows Paragon 4004-71 can be replaced with Intermatic T-104 timer.
Intermatic cross reference link:
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
Lowes and Grainger and many other outlet sell T-104 240V timer.
5) How to wire T-104
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Paragon 7008-00 timer parts:
http://www.paragontimecontrols.com/parts_accessories.htm
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
