Question about Puma Active Collection Fluctuation PU910202002 Watch
Hye! my father had bought me a puma watch last week that use some sort of touch screen in saudi.. the problem is.. i don't know how to use because it didn't come with a manual book inside the box.. sometimes i can change the channel to chronograph or set time but most of the time i don't know how to use it.. can you help me.. i'm not so sure about the model but i think maybe the model is 910191001 digital watch.. i like the watch but i don't know how to use it.. please help me.. this is my email address: ashleyamanina@yahoo
SOURCE:
SOURCE: setting the time for the puma sirius
Finally got it! Take a sharp ball-point pen and push it into the hole/bitton on the lower left side of the face. When I first tried it a zillion times, I could not get anything to happen. Then I handed it to my husband, and he said that you have to push it in with a little bit of force (more than mine, anyway) and the "setup" mode appeared. After that first time, it doesn't have to be pushed as hard!
Posted on Jan 01, 2009
mcdevito75
  • 1970 Answers
SOURCE: replacement/repair of Puma #PU100041004 Watch Leather bracelet
mcdevito75 here, You can try to contact Puma watches online, try Puma watches.com or look for a small watch repair shop in your area for replacement strap.
Posted on Jul 10, 2010
mcdevito75
  • 1970 Answers
SOURCE: Puma PU100041004 Watch Black Leather bracelet replacement/repair
mcdevito75 here, BEST BET, look for a small watch repair shop in your area for a replacement band.
Posted on Jul 11, 2010
mcdevito75
  • 1970 Answers
SOURCE: I cannot figure out how to set the time on my Puma watch.
mcdevito75 here, You can try www.puma.com They have an overseas number but also the option to find a Puma retailer in your area.
Posted on Jul 13, 2010
  • 4 Answers
SOURCE: i have Puma-Time touch screen
Dont have that particular watch, but see if this works.
Setting the time on the PU910222003 Puma ladies watch.
The process may be less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Posted on Mar 07, 2011
The buttons are not responding for my puma touch sensor 30 lap
You have to leave the light button pressed until you click there and beep and buttons work
Apr 19, 2012 | Puma Active Collection Fluctuation...
I bought a puma watch for myself about 1 month ago from Jeddah, Saudi Arabia but today it just stopped working by itself. What should I do now with it? Could it be a battery problem maybe? I live in...
yes it is the battery problem, any service center accepts battery replacement, find one on your loation. i hope i had been helped you.
Sep 11, 2011 | Puma Watches
Howdo I set time on a puma watch pu910222003 blockbuster circuit touch screen
The process is actually less complicated than you would think.
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
Feb 20, 2011 | Watches
I have Puma-Time touch screen watch (PUMA men's Blockbuster Circuit Touch Screen Black Watch but unable to set the time.
Day to day use,
Cool feature,
Feb 12, 2011 | Puma Active Collection Dynamic Posh Black...
I have Puma-Time touch screen watch (PUMA Women's PU910222002 Blockbuster Circuit Touch Screen Crystal Accented Black Watch but unable to set the time.
Dont have that particular watch, but try this.
Day to day use,
Cool feature,
Sep 17, 2010 | Puma Active Collection Dynamic Posh Black...
Replacement/repair of Puma #PU100041004 Watch Leather bracelet
Jul 10, 2010 | Puma Watches
I have bought a puma watch> I don't know the number, but it's a metal, square yellow gold-looking watch. I can't set the time. Is it possible to send me a manual. Thank you for that.
mcdevito75 here, Best Bet, visit a small watch repair shop in your area to order another manual, or visit Puma online at Puma.com. It"s possible someone here at fixya has a manual, but I doubt it. Check with the repair service directory here at fixya, bottom of this page, click on repair service directory then watches see if someone can order the manual for you.
Jun 29, 2010 | Puma Flow Analog W ( Pink/White) Watch for...
My Puma watch screen went blank?bought it April of 2010 at nike store in chicago? model 910192001? How do I solve this problem. I know its under warranty
If it had been sitting on display for long time the battery might need replacement. I'd take advantage of the warranty and have them replace the whole watch.
Jun 02, 2010 | Watches
Buttons not responding
Hey, I bought one and it's the same, I don't know how to change the time or do anything with the watch, if you already know how to make it works please tell me .. thank you!
the_paper_girl@hotmail.com
Dec 21, 2009 | Puma Active Collection Fluctuation...
Puma Active Collection Fluctuation PU910202002 Watch Logo
134 people viewed this question
Top Puma Watches Experts
Arturs Kalnins
Arturs Kalnins
Tom Chichester
Are you a Puma Watch Expert? Answer questions, earn points and help others
