The following web page has the instructions for mixing Jura tablets:
http://www.jura.com/download_information-sheet_jura_descalingtablets.pdf
I tried to find the same info in Miele's manual, but it didn't specify, but is probably the same as Jura:
http://www.cagrimmett.com/justanswer/CVA610.pdf
If you have the box or package that came with the tablets, it should say how many per volume of water. If it doesn't, contact the manufacturer.
Good luck, and hope this helps.
If you can get steam/water from your steam spout.
Fill your tank and add descale solution.
Descale according to the instruction for the unit.
After descale and rise are complete refill your water tank.
Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
