Follow the instructions found in your manual for incline calibration first. With the safety key/magnet in, press incline up, remove the key while the numbers are changing, release the incline button then reinstall the safety key. The incline should calibrate.
If the motor moves, then stops b4 completing it's cycle, the incline sensor may be defective. The sensor is the black cap/wire coming out of the top of the motor. Make sure it is connected properly.
If the sensor is defective, you have to order the complete motor to repair the problem The sensor can be replaced without replacing the motor, but it is not available as a replacement part..
Part #249516 around $110....
