Question about LG DU-42PX12XC 42 in. Plasma HDTV
The picture freezes but the audio continues to operates normally. This has happened on many occassions but is happening more frequently. Can occur after only half an hour of being turned on. We usually turn it off and wait a while (sometimes a couple of hours) before it works normally again
  • 734 Answers
Circuit overheated probably due to moisture condensation. Keep it on standby to dry off. Use it to dry off. Blow a room fan to help it dry off.
Posted on Dec 15, 2010
SOURCE:
Hi, I own a Nokia 5230. Before, I was able to record video smoothly and clearly without any kind of problem. Now, 90% of the time when I video, the video keeps going when recording, but the timer...
check if the phone memory is still at large and so on the memory card to,might so many files from your phone or card that's why the operation took some errors or buffer...
otherwise if this problem took on and so on,better reset your phone or restore it to it's factory default to refresh the memory of the phone and can do the operation smoothly...
if this solution helps....please rate me...thanks
Jun 03, 2011 | Cell Phones
All intruments stop working,radio shuts off,windows do not work.....vehicle continues to run normally...ex: if crz control is active it continues to operate normally.....problem is intermittent but seems...
try shifting into neutral when this happens and see if everything works. if so it is probably the trans range sensor. it thinks it is in the start mode and cuts the things off
Jul 23, 2010 | 2006 Ford F-150
Mac sound problems
so if your fans are over exerting themselves, your mac is working to hard..
open your activity monitor Applications/Utilities/Activity Monitor, and look at what is working so hard...Can take it from there if you post your results..
Jun 08, 2010 | Apple 3-Year AppleCare for iBook/MacBook...
I have a problem with my refrigerator not cooling consistently. It seems like at least once a day it will start warming up but the compressor doesn't come on. When I turn the temp up control nothing...
I believe this is normal behaviour in all auto defrost (which means virtually all modern) fridges. In fact, this short heating period is usually programmed to happen 2 to 3 times a day. You might rightly ask why the refrigerator compartment needs to undergo "defrost" cycles when the compartment is, if the refrigerator is operating correctly, above freezing? The reason is although the compartment is above freezing, its cooling coils are well below freezing temperature, and it's these coils that need the frequent defrosting, before they build up so much frost on them that they "ice up" and no longer allow the fan blown air that cools the refrigerator compartment to pass through them.
Nov 12, 2017 | Kenmore Refrigerators
TV freezes for a short period of time.
First a couple of questions:
1) What is the make and model please?
2) When the picture freezes, is it like a snapshot photo? or does the screen blank?
This sounds like an interruption in the digital data stream. If the picture remains on the screen, the "new" frame information is not being received nor processed. This can be as simple as a bad cable connection or noise on the digital information data lines.
Check to see if there is any pattern to when this occurs. For example, does it happen more frequently after the set has been on for a while? Try cooling down the set to see if temp effects the behavior.
Please update this and we'll work to resolve it.
Thanks,
Dan
Mar 16, 2009 | Televison & Video
Vehicle does a quick **** when driving - on occassion
possibly the bearing is going inside your distributor. see htis site for photos & files
http://autos.groups.yahoo.com/group/villagerquest/
Feb 25, 2009 | 2001 Mercury Villager
LCD TV Picture scramble/static/break up...
picture break up on all digital chanels
Feb 19, 2008 | Televison & Video
Picture jamming/break up on Digital TV
Consult with your dealer about this problem as it's not normal...accordianman
Split screen, dark and then light, picture freezes
From what source ? Does it happen when you play a DVD ?
Cable direct? Cable box? Satellite box?..........T.
Dec 14, 2007 | Hitachi 43FDX01B TV
IRiver freezes, then dies
Hi frequency squeal = diode short-circuited
Must be replaced - cannot be repaired
Mar 02, 2007 | iRiver iFP-895 MP3 Player
LG DU-42PX12XC 42 in. Plasma HDTV Logo
63 people viewed this question
Ekse
