Washing Machines Logo
Anonymous Posted on Jul 01, 2008
Kenmore HE2plus wont spin...F-21 error
I have a Kenmore HE2plus washing machine that will not spin...all other parts of the cylcle seem fine, I am getting an error code F-21. What do I do?
  • Anonymous Mar 28, 2014
    Kenmore error code 21 on washing machine
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 02, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
731
Points
Apparantly the F21 error means there is a drain problem...I removed the drain hose from the output in the wall and held it down at ground level and let it drain into a pot...I ran the rinse, drain and spin cycle while I did this but before I hit the start button I hit the 2nd rinse button to turn off the rinse portion of the cycle. It seems to be draining fine now.
Kenmore He2Plus washing machine goes F-21 with 10 minutes left in the rinse/drain cycle.
disconnect the heating element, do a wash and if it goes through the hole of the wash with just cold wash then the resistance in the heater element is gone. even if element works it can still be the problem as the computer reads the resistance on drain cycle.
1helpful
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Kenmore he2plus what's troublecode f-21
F21 on the tech sheet says Long Drain If the drain time exceeds 8 minutes the water valve turns off.
NOTE: After 4 mins the "Sd" error will be displayed then 4 mins later the f/21 error code will be displayed.
Press Stop two times to clear the display.
(Solutions:) Check drain hose
unplug washer and check electrical connections at pump
Check filter for foreign objects
If these fail it says to replace pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/geneva_f6ab09a476387fe3
Kenmore HE2Plus White Front Loader. Drain pump seems weak, wet clothes, and f-21 flashing..???
Hello & Welcome to FixYa
F21 error code is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Kenmore HE2plus Front loading/ model 4754. Full of rinse water. Will not eject the water. Flashing an F-21 error. What is the F-21 problem,
Welcome to FixYa.
Try this link of my solution for this issue...it is very common.
http://www.fixya.com/support/t7367730-f_21_error_displayed
Let me know how it goes and if you require further assistance.
Thanks for choosing FixYa. Please take a moment to rate the solution provided for you here today.
Good luck.
Regards,
Macmarkus :)
F-21 error code, washer stops
Check for the drain hoses(both sides of the pump) and check for a blockage,then check the pump for blockage,there should be 4 impellers on this pump and they can get broken off by coins and debris.
Thank you !!
2answers
How do I fix my Kenmore washer spin cylcle? It
if your machine is a top load , less than 15 yrs. You most likely need a new lid switch. The machine will not drain or spin if the top lid is open.
He2plus does not drain and spin
code F24
WATER TEMPERATURE SENSOR ERROR
next information is only for the TECHNICION
If the water temperature sensor NTC value is out of range (23 F to 217 F to 103F C) during the water-heating step of the WASHcycle.
NOTE:To find corrrect Ohm reading refer to the water temperature sensor in TECHNICION ONLY section.
Possible couse/Procedure
1.- Unplug washer or disconect power.
2.*check the water senser and conection to it.
3.-check resistence of heating element, if present on this model(abnormal=indifinity)
4.-refer to the water Temperature Sensor section
Am sorry but F7 error code is not in the information system.
"Was this helpful?"
1helpful
Kenmore he2plus washer
Error F 28 is your heater and it will not unlock because of it.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1176579&PPStack=1
Here is the part info thanks
Top Washing Machines Experts
john h
